Central locking pump
Old Jun 5, 2024 | 11:25 PM
JerryDPruitt's Avatar
Default Central locking pump
I have a 2006 roadster and am having an issue with my CLP. When the large electrical connector is plugged into the pump my hazards turn on. Cannot turn off with hazard switch. I have to unplug the connector to the pump. The convertible will not go down and the door will not lock. Power top switch flashes. When I turn the handle for the top, the windows do go down but that's all that happens. Pump has no water damage and I do not believe there are any fuse issues. Please help. I would like my top to work and my doors to lock. Thanks inadvance
Old Jun 6, 2024 | 09:01 AM
Default Re: Central locking pump
How long have you owned it and what led you to the central locking pump?
Old Jun 6, 2024 | 09:04 AM
Hello, I have owned the car for about 2 years. The pump was not working when I bought the car and replaced the pump. When I replaced it I started having the hazard light issue and pump really doesn't do anything. No fuse issues.
Old Jun 6, 2024 | 10:47 AM
The reason I asked is because if the old pump got wet, the connectors can also be damaged. There is also no wat to know if the replacement pump was good.
Heelsfan
Jan 9, 2025 10:29 PM
stevemccl
Apr 29, 2023 02:59 PM
Sixkay
Sep 20, 2021 11:18 AM
IamNIkoSuave
Aug 6, 2019 05:58 PM
