Instrument Cluster Rmoval
Old Aug 17, 2025 | 09:58 PM
maggy55's Avatar
Default Instrument Cluster Rmoval
Ok, I followed the instructions for Skreem replacement. However , I need to pull the instrument cluster all the way out. I have rodent damage behind it. I'm not sure how to release the wiring connectors. I don't want to break anything. Any advice would be appreciated.
Thanks
OKAY i FIGURED OUT, THANKS
Old Aug 18, 2025 | 11:47 PM
Default Re: Instrument Cluster Rmoval
Thanks
Geeze Maggy, hope that's all the critters ate..... Good luck with the fix!
Old Aug 18, 2025 | 11:58 PM
Thanks
I'm glad that you figured it.
Best of luck to you and I hope that you get it repaired soon!
Old Aug 19, 2025 | 01:44 AM
maggy55's Avatar
Thanks, at least I think I found the problem
Old Aug 19, 2025 | 03:52 PM
Instrument Cluster Cover
REMOVAL
  1. Remove the steering wheel.
  2. Remove the lower instrument panel.
  3. Remove the sentry key antenna ring from the key cylinder.
  4. Remove the screws attaching the instrument cluster cover to the lower instrument panel.
  5. Disconnect the instrument cluster cover (1) from the top with a plastic wedge.
  6. Tip the instrument cluster cover toward the rear at the top. Lift it over the jacket tube covering and simultaneously guide the adjustment ***** through the cover.
INSTALLATION
  1. Tip the instrument cluster cover toward the rear at the top, then lift it over the jacket tube covering and simultaneously guide the adjustment ***** through the cover.
  2. Connect the instrument cluster cover (1) to the instrument panel top section.
  3. Install the screws attaching the instrument cluster cover to the lower instrument panel.
  4. Install the sentry key antenna ring to the key cylinder.
  5. Install the lower instrument panel.
  6. Install the steering wheel.
Old Sep 7, 2025 | 08:38 PM
maggy55's Avatar
Believe it or not , after repairing those four wires everything works. No more engine light, no more high speed fan , no more cluster gauges going up and down , no more 36F degree reading. I'm shocked.
Old Sep 8, 2025 | 09:33 PM
I'm glad that it all worked out! Thanks for letting us know.
BobG
Jan 19, 2023 11:04 PM
dedwards0323
Apr 27, 2022 10:31 AM
Shamrock
Feb 3, 2022 08:10 PM
Hitch
May 9, 2021 10:41 AM
Toolman
Jan 12, 2018 11:49 AM
