instrument / gauge cluster removal
Old Jul 29, 2020 | 01:43 PM
Hitch's Avatar
Default instrument / gauge cluster removal
Hi everyone.
I need a little advice on how to remove the instrument cluster. I'm trying not to break anything.
I looked in the repair sections but did not see anything that helped.
I have a few lights that are out that I want to replace.
Thanks in advance for your help.
Hitch
Old Jul 29, 2020 | 01:53 PM
WD40's Avatar
Default Re: instrument / gauge cluster removal
Originally Posted by Hitch
Hi everyone.
Hitch
Here's the procedure on a Mercedes R170. It is not 100% the same as a Crossfire, but I'm hoping it's close enough to get the job done.
Old Jul 29, 2020 | 02:30 PM
Hitch's Avatar
Thumbs up Re: instrument / gauge cluster removal
Thanks WD Knowing where those hidden screws are will save the day..or a least a couple of cuss words...
Do you happen to know the 2 watt bulb part number?
Hitch
Old Jul 29, 2020 | 02:45 PM
WD40's Avatar
I searched and found these:
What bulbs to use:
https://www.crossfireforum.org/forum...ght-bulbs.html
MUST READING before attempting disassembly:
Remember I told you it is not 100% the same (vs R170)? This thread points out the differences:
https://www.crossfireforum.org/forum...ter-bulbs.html
Old Jul 29, 2020 | 03:19 PM
More info here.
Old Jul 29, 2020 | 07:47 PM
Hi everyone.
Some advice on what part of the forum to post in might be a good idea as well..............
Old May 5, 2021 | 07:11 PM
Jim Holian's Avatar
WD40 - Thanks for posting the video on the gauge cluster removal. I referred to it several time's removing mine. Of particular concern to me was the removal of the electric supply on both the right and left side. I could not find a thing on that in my shop manuals.
Thanks again,
Jim
Old May 6, 2021 | 11:08 AM
WD40's Avatar
Thanks again,
Jim
Thanks Jim. I too bought the 3-volume Chrysler factory Xfire shop manuals which generally go for just shy of $200 for a good-quality used set. They are a boon and well-worth having for anyone who does their own maintenance. But EXACTLY LIKE YOU SAID it never mentions removing the electrical supplies! No one is perfect, but that seemed like a key thing to me too! That's the true value of this forum, because you can bet that as humans we're not that different, and thus subject to experience the same headaches. Thanks. Your mentioning this makes me more likely to share to share what I experience in the future.
Old May 6, 2021 | 02:07 PM
IF and WHEN you pull your cluster, make sure you REMOVE the NEG battery cable from the battery before you start pulling electrical plugs in the dash. A word to the wise!
Old May 6, 2021 | 06:50 PM
Jim Holian's Avatar
GraphiteGhost - Enlighten me on your post. What are the ramifications of leaving the neg. terminal connected? In most cases, I leave the battery connected because I don't want to lose anything in the storage part of the computer. Let me know about your posting.
Jim
Old May 6, 2021 | 10:12 PM
BobG's Avatar
Remove the cable from the negative battery terminal! You're working near airbag in the steering wheel.
Also, it's just good practice when separating electrical connectors.
Old May 7, 2021 | 04:09 PM
Jim, what BobG said! Always a good idea when opening up electrical connectors with many of the electronic modules in these newer cars!
Old May 7, 2021 | 06:31 PM
Jim Holian's Avatar
Thanks fella's! Duly noted.
Jim
Old May 8, 2021 | 06:53 PM
Hitch if u screw yours up and need a spare cluster (limited) let me know 25 + shipping jim
Old May 9, 2021 | 10:41 AM
Jim Holian's Avatar
AMX1397 - Thanks for the offer but everything went fine. Works well and looks so much better than the original black gauges.
Jim
Bobba Fett
Jul 22, 2021 07:29 PM
sanfoor
16
Dec 23, 2013 06:42 PM
steve1173
Oct 31, 2007 12:42 PM
cgocifer
Oct 6, 2007 06:06 PM
NXM
Feb 10, 2007 06:02 PM
