Australia Serving Australia.
hood lining
Old Jan 22, 2018 | 05:27 AM
saltiga's Avatar
Default hood lining
We have has a few hot days of 40celcius , went to use the crossfire only to find the hood lining has fallen in , I think its the lining that has left the backing, Has any one had this occurrence , has any one removed the hood lining . If so is there any traps? Saltiga
Old Jan 22, 2018 | 07:29 AM
waldig's Avatar
Talking Re: hood lining
Took mine off first thing, stored it, worthless to me, enjoy Woody
Old Jan 22, 2018 | 11:43 AM
bluecoupe's Avatar
Default Re: hood lining
It's common for the headliner sponge/foam to fail, especially in warm climates. There are many forum member posts on this topic.
Old Jan 22, 2018 | 12:51 PM
Are you meaning hood or head lining?
It gets hotter than that under the hood with no problems, I cannot see it falling apart.
I am sure you meant headliner.
Edit
I am told he is from Oz and he is all upside down, so hood is headliner there I am told.
Old Jan 22, 2018 | 08:48 PM
waldig's Avatar
More:
https://www.crossfireforum.org/forum...-help-you.html
enjoy, woody
Old Jan 22, 2018 | 11:32 PM
Larry Hitze's Avatar
I took mine to a local upholstery shop to be recovered about 3 years ago. I took it out of the car and reinstalled it myself. It cost about $100 USD.
Old Jan 23, 2018 | 12:45 AM
pop49's Avatar
I have just done my 'roof liner', follow the removal procedure on utube, comes out easy. get a stiff brush and remove all the crappy left over foam, it cost me about $ 90 to do. !.3 mtrs and a can of adhesive. a shop will charge you around the $250 plus mark. i had to do mine to get it over the pits.
Dont bother trying to get all the old glue off. just brush and wipe over with some acetone.
came up a real treat.
Old Jan 23, 2018 | 08:45 AM
Assuming you actually mean the hood liner, mine has a little sag in it also. But not enough yet to be an issue. The first time I noticed "the sag" was when I saw a smudge mark on the air cleaner housing. If & when it becomes a major issue, I'll probably remove it and install an after-market version that has a reflective covering.
Old Jan 23, 2018 | 05:29 PM
saltiga's Avatar
Why don't you yanks learn the Queens English, But if you must it is the headliner, Actually if we are in the country upside down then the "HEADLINER should be still in tact! Thanks for the enlightenment and info. Saltiga
Old Jul 11, 2024 | 07:56 AM
MCPO's Avatar
Default Re: hood liner
I bought a new HOOD LINER! They recommend removing hood before installing, using spray glue and plastic fasteners! I’m surprised that I can find NO videos on how to remove hood safely!
Old Jul 11, 2024 | 05:00 PM
DTMenace's Avatar
MCPO
Is the new hood liner an aftermarket product or an original equipment liner? Regardless, there is NO requirement to remove your hood to install a liner. You should NOT glue it to the underside of the hood! Just use the OEM clips and that should secure the liner.
Good Luck....
Dennis
DTMenace
Old Jul 22, 2024 | 05:09 PM
DTMenace's Avatar
MCPO
Click on the link below, its an OEM style hood liner and the available fastener clips. NO GLUING REQUIRED!
Dennis
DTMenace
DHP Hoodliner - Compatible with: (2004-2008) Chrysler Crossfire | eBay
Lee337
Mar 22, 2012 04:49 PM
manisusmc
Jun 3, 2010 04:36 PM
oceansideaddict
May 15, 2009 12:57 PM
willie
Feb 16, 2009 08:55 AM
tbrenan
Apr 3, 2008 10:19 PM
