Australia Serving Australia.
ECU and SKREEM Problems
Old Nov 20, 2023 | 07:22 PM
Mearsy's Avatar
Default ECU and SKREEM Problems
Hi all. looking for some advice for my sons 2005 Crossfire ZH Coupe. The battery went flat and it was sitting flat for some time as he only drives it every so often. The car initially cranked and started once the battery was charged but would run for a bit then stop. Now the car wont start/crank at all. I watch a youtube video about bridging out a cable to the starter motor and when i did this the motor cranked. The car has already had the crank sensor replaced. Ive since been told by an auto electrician that the SKREEM unit has probably lost its settings. Further to this, the auto electrician is unable to connect to the ECU with the ODB reader. he is telling me that the ECU is dead and the SKREEM is dead. Ive looked on line and can purchase ECU/SKREEM units from the US but would prefer some expertise in Australia. Can anyone point me in the right direction please?
Old Nov 21, 2023 | 09:05 AM
Default Re: ECU and SKREEM Problems
Go online and find MSS, Mercedese Swap Shop and call them for advice.
Old Nov 21, 2023 | 04:30 PM
CL770's Avatar
Hi Mearsy
I'm in Brisbane and I can fix that for you. Send me a PM and I'll send you my mobile number so we can talk.
Old Nov 22, 2023 | 07:54 PM
red_2005_convertible's Avatar
Hi Mearsy,
Before you fix the SKREEM and ECU, check your RCM - if it goes bad, then the ECU doesn't get power. RCM is the most common failures for XFs.
-Jerry
Old Nov 24, 2023 | 04:57 PM
Mearsy's Avatar
Thank you guys for your responses. Seems it maybe be the RCM and special thanks to CL770 for sending a refurbished one to me. I'll test it out and report back to the thread. Appreciate the help.
Old Dec 3, 2023 | 07:14 PM
GannyX's Avatar
IF you do need a skreem repair * We do worldwide* Just message us at The MSS
saltiga
Australia
May 7, 2023 05:04 AM
AlabamaCrossfireRoadster
Mar 9, 2023 01:31 AM
Agarcha
Nov 23, 2020 09:43 AM
SRT6STORM
Sep 1, 2011 10:54 PM
