Rear alignment?
Old Mar 23, 2006 | 02:34 PM
stlxfire's Avatar
Default Rear alignment?
Does the rear suspension have adjustment? Despite the pretty heavy camber, I have some outside wear on the right rear conti. Not so much on the left. I wouldn't think I drive that differently right to left! Just over 27k on the ContiTourings...will need replaced soon.
Old Mar 23, 2006 | 02:41 PM
danimal's Avatar
Default Re: Rear alignment?
Natural tendency to accelerate harder turning left than right, which would wear the outer edge of right rear tire. Just the opposite in right-hand drive vehicle.
Old Mar 23, 2006 | 04:16 PM
+fireamx's Avatar
Since it is an IRS, I'm sure there are adjustments that can be made. You're not by chance hauling to much weight in back are you? The Crossfire has a pretty "limited" cargo weight capacity. Since the Conti's aren't directional, try rotating them.
As Danimal pointed out, maybe your cutting those left hand apex's a little faster than the left ones and just don't realize it.
usprb1976
Apr 4, 2024 04:57 PM
blackpepper
Dec 18, 2021 06:17 PM
Jonacross
20
Jul 17, 2017 11:19 PM
UNDER PSI
Nov 1, 2015 09:39 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
