Squeezing More Kw Out
Old May 20, 2006 | 05:04 AM
DOC CC's Avatar
Lightbulb Squeezing More Kw Out
I have had my crossfire (not SRT) for a year now. The problem is at the lights the crossfire is flat in first gear (my impression). It's only when I hit second that the crossfire surges ahead. I'd like to know what's the best and no fuss method to increase pull away from the lights? I know a guy that "chipped" his Volvo S60 and the take off is spectacular (I know this is a crossfire forum but bear with me!). Apparently it had something to do with advancing the timing!!?? Anyway - any suggestion from you peeps would be welcome.
Old May 20, 2006 | 05:40 AM
bobs's Avatar
Default Re: Squeezing More Kw Out
You could always press down on the accelerator pedal a bit further. That normally does it for me!
Seriously, do you have the automatic or the 6-speed? I can't speak for the auto, but I have found that with the 6-speed, first gear is very short and with proper application of the throttle and smoothly feeding in the clutch (a.k.a. "don't trigger the traction control or ESP") launches from a stoplight can be truly impressive.
As far as performance mods go, they have been discussed at great length many times before. Head over to the technical forums and poke around a bit, or use the "Search" function. I bet you'll find what you're looking for.
Old May 20, 2006 | 08:48 PM
stryfox's Avatar
WE need gears but, it seems we cant have them, They are not available, you would need to spend big $$$ to have a set made.
You can do a search about the chip/reprogram... There are mixed feelings about them.
Old May 21, 2006 | 04:38 PM
markr6754's Avatar
I thought that I was alone with this problem. I hadn't driven a stick for quite a while, and the last one I drove that actually had any power was my Das's '63 Stingray. In driving feel and sound, my Crossfire brings back many of the same memories...but there's nothing similar in the starting line performance. Power kicks in hard in 2nd and 3rd, but I can't seem to get a good start. The one time I did SEEM to get a starting charge the Stability Control kicked in and shortened my enjoyment. Fortunately, it doesn't come in to affect the higher gears.
Maybe we need some racing lessons, as I am sure I've forgotten how to do this...and there's not much opportunity for practice.
pct
U.K.
18
Jan 20, 2023 08:03 PM
massanu
Nov 25, 2015 12:39 PM
70GS455
Nov 15, 2011 10:28 AM
GraphiteGhost
Dec 16, 2010 08:07 AM
Skip080944
Nov 26, 2008 07:00 PM
