Oil Change, Smells like Gas?
Old 06-12-2006, 11:05 PM
aallman72's Avatar
Default Oil Change, Smells like Gas?
All-
I just changed the oil & filter in my XF tonight from the 10w30 that the deal put in when I got it and it smelled a lot like gas.
Is this normal?
Or does thins mean that the dealers thicker 10w oil has caused a gasket somewhere to leak/blow allowing gas into the oil?
Thanks
Old 06-13-2006, 06:50 AM
bobs's Avatar
Default Re: Oil Change, Smells like Gas?
More than likely it is from blow-by, which is when some of the air/fuel mixture or combustion gasses leak past the piston rings on the compression or power stroke. If you're sure the dealer put in 10w30 you should go back and raise he|| because that is clearly outside of the recommended viscosity listed for that car. Make sure that the fact gets recorded in the car's maintenance history so you'll have documentation for any future warranty claims.
xfClifford
03-03-2021 04:52 PM
PNA
11-12-2020 04:44 PM
xfireohio
07-20-2020 12:03 AM
sittininthesun
08-24-2015 10:47 AM
skeet370
07-18-2015 01:02 PM
Quick Reply: Oil Change, Smells like Gas?
