Washed and waxed... finally took a picture or two :)
Old Jul 17, 2006 | 08:00 PM
intenseblu's Avatar
Default Washed and waxed... finally took a picture or two :)
this poor crossfire stood around for seven months in the bitter outdoors waiting to go to a good home so it had plenty of swirl from being washed in haste by the dealership and some kind of white dotting as if from air borne paint...
so i had some time over the weekend to break out the meguiar's cleaner wax and give it a coat... looks better now, but still needs some more TLC so next weekend i will give it another coat...
these are also the first shots i have of the ADR M-Sport 18" wheels with spacers in the rear ... i'll measured and cut the bolts to the size i needed for the rear over the weekend, it was tedious work to do that kind of micro surgery so that the threads would come out perfect ... i'll post the tire/wheel combo in the tire/wheel section later or you can get it from the description in my gallery.
anyone else do some work over the weekend ?
Old Jul 17, 2006 | 08:52 PM
chuckd's Avatar
Default Re: Washed and waxed... finally took a picture or two :)
Looks sweet!
I'd like to see it in some better lighting!
Rims look nice!
Old Jul 17, 2006 | 09:14 PM
HDDP's Avatar
sweet dude. no more need be said !!!
Old Jul 17, 2006 | 09:45 PM
Sennaspirit's Avatar
I'll second (or third) that! Ok blue, I posted a comment on your gallery today about your wheel/tire set up, you and I definitely have the same thing in mind...so give us the details, what size wheels (look the same all around, yes/no?) and what tires/sizes did you put on. I like it, but can we get a better side view?
Well done!
Old Jul 17, 2006 | 09:48 PM
andrew's Avatar
-C-I-C-C-I Associate Member
looks pretty menacing.
Old Jul 17, 2006 | 10:33 PM
intenseblu's Avatar
Wheel specs:
ADR M-Sport
18 x 8.5 front on 235/40/18 Continental Extreme Contact (.3" taller)
18 x 9.5 rear on 275/40/18 Continental Extreme Contact (.7" taller)
No spacers in the front, 20 mm hubcentric spacers in the rear. Needed shorter bolts up front and longer in the rear. Also had to clearance some of the upper ball joint bolt end in the front to prevent tires from touching.
Here is a better side shot:
Old Jul 17, 2006 | 10:47 PM
Fritzauf's Avatar
Nice photos! Looking good!
Old Jul 17, 2006 | 11:15 PM
chuckd's Avatar
Why no 19s on the rear? Would be the bomb with 19s on the back with 275/35s.
Old Jul 17, 2006 | 11:23 PM
Eracer76's Avatar
It does look good, but I was thinking the same thing as you, it could have been the bomb!
Old Jul 17, 2006 | 11:33 PM
intenseblu's Avatar
i went with 18" cause i need a all season tire that can actually go through snow ... so 19" where out as there are no good options ...
for next summer i will have a set of 19s with KDW tires for the rear only as my track tire (only cause i will need the traction of a more aggressive tire like the KDW by then) ... but for daily driving 19"s are only the bomb if you mean the sound they make when the tire pops and the rim splits.
potholes are a Jersey specialty...
Old Jul 17, 2006 | 11:59 PM
HDDP's Avatar
You'll have a lot more 18" tires to choose from... 19's are few and far between... Plus, as you said, the thicker sidewall will keep you from destroying your wheels on those pot holes in joizee...
Old Jul 18, 2006 | 12:11 AM
intenseblu's Avatar
yea HDDP, when i did my research and did the search for 18s it was like a whole new world. there are way more tires available at way way way better prices than 19s... i think you where the first person to try 18 inch wheels that i know of on these forums so yea, you go trend setter. :P
TerryR
Dec 13, 2019 03:27 PM
aerobluehal1
Canada
19
Oct 13, 2018 09:47 AM
steps
Apr 26, 2016 06:21 PM
o55ie18
Oct 5, 2015 05:50 PM
Mackel
Sep 29, 2015 02:41 PM
