Cup holder will not stay down
Old Aug 4, 2006 | 10:31 PM
Doug Magill's Avatar
Question Cup holder will not stay down
I know this is a much discussed topic the "cup holder" and I have checked out others posting. Mine has quit latching back down. Latching may be the wrong word but there must be something that it catches on. I would think that there must be something to adjust in it. I am not interested in duct taping it down.
Old Aug 4, 2006 | 10:45 PM
andrew's Avatar
-C-I-C-C-I Associate Member
Default Re: Cup holder will not stay down
it will need replaced under warranty... most likely a broken latch/catch clip.
Old Aug 5, 2006 | 11:26 AM
BullFrog's Avatar
The exact same thing happened to mine and it had to be replaced. However when they replaced it they installed the '04 glossy finish one on my '05 matte finish so make sure you bring that up to them before they replace it.
Old Aug 5, 2006 | 01:06 PM
jmlg's Avatar
This has happened to me too.
Is it in my best interest to call and make an appointment for something like this?
Old Aug 5, 2006 | 01:59 PM
BullFrog's Avatar
It all depends if you're dealer is on an appt basis. See the dealer i go to they know me from all my XFire purchases there so i usually don't make an appt. I just call ahead that i'm bringing in the car and just come in and drop off and they give me a loaner. However i do advise to call them up before and let them know what you need to make sure if it's in stock and if so if its the correct finish on it.
Old Aug 5, 2006 | 03:52 PM
RickB's Avatar
With the manual transmission, I found the cup holder more than useless. There is a TSB that will allow you to replace the cup holder with a small storage bin. I never used the cup holder, but the storage bin has been very useful.
Old Aug 6, 2006 | 02:11 PM
jpristel's Avatar
That cup holder held a full 32 oz drink without spilling a drop through a 20 mph crash in my car... The sheer inertia of the drink at that speed broke the cup holder though, but hey, no spillage to further ruin an already awful day is fine by me...
Old Aug 6, 2006 | 02:41 PM
upstate's Avatar
If my cup holder broke I would want another. I agree its placement was clearly an after thought and not the best spot but it works great and is better than nothing. Remember in Europe they get in cars to drive, nothing else. It is we American's that want cup holders, they almost resent it. So I guess the compromise was one misplaced cup holder.
Old Aug 6, 2006 | 06:44 PM
RickB's Avatar
I assume you have an automatic. With the manual transmission, every other shift put my elbow into the cup holder. I only used it once, but the passenger was getting tired of picking up the cup. I now use a "clip on holder" on the side window where its out of the way.
Old Aug 10, 2006 | 08:00 AM
buckeyedad42's Avatar
Cool Re: Cup holder will not stay down
Just like in golf alter your shift plane keep your elbow at your side! I don't have a problem with my manual shift and the cup holder unless I reach over and grab some part of my wife.
Old Aug 11, 2006 | 09:15 PM
ctsemicon's Avatar
Hey guys, here is one quick fix...the cupholder works great (at least on my 20 oz Steel coffee monster). The annoying trait is that it pops up into position with the ever so slightest tap...want to keep that bugger down in the hole 'till ya need it?...Well, then, if you disassemble the console (cupholder mounts from underside), you can remove the spring that loads it to the "use" position (small spring coil with wings at 90 degrees). Then you have to "manually" (oh, the agony!) press the rear of the top silver part, and it will lock into position just like always (extend spring and latch are separate mechanisms). Makes the damn thing much easier to live with. I did discover you can do this mod without removing console - the cupholder itself will pop out of housing if you pry it out just so...best regards...ct
Old Aug 12, 2006 | 02:13 AM
Thank you ctsemicon that was the info I was interested in. I am sure it isn't broken and going to the dealer and give them the opportunity to screw something up isn't something I want to do unless it is the last resort. I have a feeling it is something that can be adjusted. I have owned several British sports cars - always something to fix or adjust. Builds character.
Thanks again.
steps
Apr 26, 2016 06:21 PM
Reliableron
Oct 17, 2015 10:19 PM
maxcichon
Sep 28, 2015 07:34 AM
eatmycrackers
Sep 23, 2015 09:08 AM
Wisconsinfdcrossfire
Sep 20, 2015 10:04 PM
