Check eng light?
Old Sep 13, 2006 | 04:24 PM
BRappaport's Avatar
Default Check eng light?
Hi,
I've read most of the forum inputs on the "check eng light" and it seams that the likely issue is the "gas cap". I have less than 5,000 miles on my Crossfire, and now have the check eng light on. I removed the gas cap, cleaned the gasket, and reseated the gas cap. I have driven it for 4 days, but the check engine light is still on. Does the dealer have to reset the light...or should it reset itself...if the gas cap was the problem?
I have an appointment at the Dealer tomorrow. Comments appreciated.
Thanks.
Old Sep 13, 2006 | 04:59 PM
cgates's Avatar
Default Re: Check eng light?
If the problem was the gas cap, it should clear after a few starts with a few miles on each start.
If it doesn't clear, or stay cleared, have the dealer read the error code and fix the problem.
My check light would come on and go off after about 3 restarts, I replaced the gas cap, without success. Turned out to be a bad relay that had to be replaced.
BTW, the first dealer I took it to, 5 start where I bought the car, cleared the fault, said it was a vacuum leak, but didn't find a problem. The next dealer I took it too, non-5 star, read the code, spent a lot of time working the issue and found the bad relay.
It all depends on who is doing the work.
Old Sep 19, 2006 | 08:27 PM
BRappaport's Avatar
CGates...
I took of the gas cap and cleaned the gasket...and reseated the cap...light stayed on for 3 days...I was on my way to the dealer...and the light went off...
I think that was the 3rd or 4th time I started the car.
I cancelled my dealer appointment...Have now driven the car for another week...light is still off...So you were correct...it takes several engine starts and miles before the sensor will reset itself...Thanks.
Ben
Old Sep 19, 2006 | 08:54 PM
acrispy1's Avatar
My car is going in tomorrow for the check engine light. I already know its the cam relay, a friend of mine checked it for me now I'll see what the tech says.
Old Sep 19, 2006 | 09:16 PM
stryfox's Avatar
Just remember if the check engine light is blinking! stop driving immediately!
If it is just lit it is a trouble code.
Blinking is dangerous failure.
Old Sep 19, 2006 | 09:33 PM
BRappaport's Avatar
Cool Re: Check eng light?
Thanks for the warning...luckily mine was lite continuously. But now I know for the next time. But...Hope there's no next time.
I know from other cars I've had that a check engine light is frequently caused by a bad oxygen sensor. Does the Crossfire have many of those?
Happy Motoring!!!
Thanks
Old Sep 20, 2006 | 12:28 AM
Idaho's Avatar
When in doubt go to Auto Zone, Shucks or Pep Boys, they'll read the fault code for you at no charge. Then all you have to do is look it up the PCode in the service manual and see if it is serious or truly just the gas cap. I am guessing the code for a gas cap issues would be one of the following:
(P0451) FUEL TANK PRESSURE SENSOR PERFORMANCE
(P0452) FUEL TANK PRESSURE SENSOR CIRCUIT LOW - Most Likely
(P0453) FUEL TANK PRESSURE SENSOR CIRCUIT HIGH.
Old Sep 20, 2006 | 08:55 AM
X_firedude's Avatar
if the light was just a one time failure... not a broken something. just disconnect the battery for a couple minuets and the light should go off.
skeet370
May 15, 2018 12:57 PM
jgreen
106
Sep 18, 2017 11:46 PM
wruss
Feb 8, 2017 01:05 PM
axnguyen
Jul 21, 2015 11:41 AM
Mark McKay
Jul 17, 2015 01:18 PM
