Radio
Old Sep 14, 2006 | 08:36 AM
billy1's Avatar
Default Radio
Hi, I am new to the forum. I drive a '04 crossfire coupe. Very pleased with the car only had it a week. Can anyone help with a little problem. The radio reception is rubbish. The radio will hold the stations but with terrible interference.
Old Sep 14, 2006 | 10:01 AM
MMZ_TimeLord's Avatar
Default Re: Radio
I haven't experienced this problem. I also have a coupe and the built in antenna in the rear glass seems to work just fine.
I'd get it checked at a reputable stereo installation shop. It may be something simple like a loose or not completely seated antenna connector on the back of the stereo.
Do you have the factory unit? (It should be silver with silver buttons and a monochrome display).
Old Sep 14, 2006 | 10:48 AM
golfergal's Avatar
Default Re: Radio
I have a static situation going on with my radio. I get a series if 3 static-like sounds off and on while driving. I've thought it was maybe my phone interfering with the reception, and that might still be the case, but the phone was not plugged into the adapter and it was not ringing nor active when I hear the static's...I do have an Igo recharger for my phone after my original would not charge my phone. However I had the static before and after these adapters. Any ideas???
Old Sep 14, 2006 | 11:14 AM
Thirteendog's Avatar
Default Re: Radio
Are you listening to AM or FM? I listen to AM a lot and have to live with the static sense the built in antenna isn't long enough to pick up AM well.
Old Sep 14, 2006 | 02:00 PM
Default Re: Radio
GolferGal,
If you have Cingular service, you will hear your phone interfere from time to time. It happens on most amplified stereo systems... home or automotive.
It's actually the cell phone interference hitting your amplifier and/or speakers... I've just learned to tune it out.
If you are not with Cingular... you can find out if it's your phone by turning your phone off when you drive the car (presuming you're not expecting any important calls). If you still get the static, it's not your phone.
Old Sep 14, 2006 | 06:16 PM
golfergal's Avatar
Default Re: Radio
Bingo...I have Cingular, and I turned off my phone and unplugged my adapter...no more static...guess I need to get use to the noise.
Old Aug 1, 2007 | 09:54 PM
stlouistrucker's Avatar
Default Re: Radio
Am I understanding that this might be specific to Cingular?
I have Cingular and have the problem with my speaker phone at work but haven't noticed it in my Crossfire.
Old Aug 1, 2007 | 11:45 PM
Default Re: Radio
No it's not carrier specific. It happens with GSM and 3G devices.
Old Aug 1, 2007 | 11:52 PM
bugeye's Avatar
Default Re: Radio
Does your rear glass have tinted windows? If so and its a high metal content thats your problem. I have the same one since I had them tinted.
Hope this helps.
Old Aug 2, 2007 | 12:03 AM
Mike-in-Orange's Avatar
Default Re: Radio
I have a Roadster with the black stubby antenna on the left rear quarter panel. Radio reception is not so great on AM, sometimes problematic on FM. I have Verizon, by the way, so it's not a cell phone issue either.
Old Aug 2, 2007 | 11:44 AM
gibsonjunkie's Avatar
Default Re: Radio
My new dealer actually found a TSB about the Roadster antenna mount and AM reception. I'm supposed to get it replaced tomorrow.
Old Aug 3, 2007 | 12:11 AM
chuckd's Avatar
Default Re: Radio
Our XF won't get a single AM channel anywhere. Never has.
Old Sep 7, 2007 | 05:19 PM
jknemeyer's Avatar
Default Re: Radio
I have an '04 crossfire. Radio reception was pretty good at the beginning. Not as good as other cars in hilly or remote areas.
Recently, the a.m. reception became intermittent. Going to work it was fine. Coming home it was not. Pretty soon, the a.m. was terrible all the time, unless I am very near the location of the station.
Had Chrysler check it out. They said everything is fine. The pulled out the radio and ensured the antenna was connected. It still does not work.
I suspect the connection between the rear window and the radio is bad. I had air-line issues that went through the same part of the rear hatch (frequent bending of rear lock's air line caused it to tear, allowing air to escape rather than unlock the hatch).
I'm trying to disassemble the console and accessible antenna lines myself. Not much luck yet.
aerobluehal1
Canada
19
Oct 13, 2018 09:47 AM
Sterling57
Apr 11, 2016 06:11 PM
smokey847
Nov 12, 2015 11:54 PM
brandoni
Sep 30, 2015 07:48 PM
Selbyl
Sep 26, 2015 04:15 AM
