lower grill
Old Sep 20, 2006 | 09:00 AM
X_firedude's Avatar
Default lower grill
hey guys i wanna take my lower grills out. but when i pull on them they don't come off. so i called my local dealer and they said if i took the grills out then i would have to take my fogs out to because they are hooked together. is this true if not how do i get them out?
Old Sep 20, 2006 | 03:37 PM
acrispy1's Avatar
Default Re: lower grill
No ... they are not hooked together, the grills pop right out. You have to grab the middle of the grill and pull on it they should pop out you may need to get a screw drive between the outside edge and the lower bumper (be careful not to scratch the car). that's what i did with mine.
Old Sep 20, 2006 | 04:30 PM
maxxm's Avatar
The lower grilles are designed to be removable to permit access to the "towing eyes" for towing. There are some useful graphics in the "towing" section of the owner's manual, FYI.
Old Sep 20, 2006 | 05:28 PM
X_firedude's Avatar
thanks guys... i love this forum.
Old Sep 20, 2006 | 05:33 PM
CrossfireLTD's Avatar
Cool Re: lower grill
Use the "Multi-Tool" just stick it into the hole and find the inner tab and the grille will pop out, as diagramed in the owners Manual.
Old Sep 20, 2006 | 11:29 PM
Eracer76's Avatar
Don't pull on the grills near the center of the car. The grills hook into the bumper piece that divides the grills. The grills snap into the bumper on the far outside edges, that is were you need to pull/unsnap them.
Old Sep 21, 2006 | 02:10 PM
X_firedude's Avatar
ok well how do i unsnap them... with the multi tool.
Old Sep 21, 2006 | 03:48 PM
There is a hole the grille, insert the tool into the hole and there is a clip that the tool will fit into then pry to the right and the grille will pop out. There is a diagram in the Owners Manual.
Old Sep 24, 2006 | 09:03 PM
porterhouse's Avatar
While I was removing my grill, I noticed a skinny probe sticking out on the right side grill. Does anyone know what that is?
Old Sep 24, 2006 | 10:52 PM
andrew's Avatar
-C-I-C-C-I Associate Member
~ it is the outside/exterior temperature sensor.
Old Sep 24, 2006 | 11:00 PM
maxxm's Avatar
Well, I guess we learn something new every day. With the sensor's proximity to the engine bay, however, I have to wonder whether that positioning might influence the reading in some way.
Old Sep 24, 2006 | 11:11 PM
andrew's Avatar
being where the sensor is located... it is more inclined to receive slightly inaccurate (higher) reading due to the heat of the asphalt... more so than the heat of the engine... being that it is so low in the front bumper.
Old Sep 24, 2006 | 11:16 PM
midnightman's Avatar
When I first got my XF, I made it a point to check the accuracy of the exterior temperature gauge. I would note the temperature when I pulled into the garage and then I'd immediately go right to the TV and the weather channel to see the local reading at the nearby airport. Each time I checked, I was shocked to see my gauge was impressively dead on.
Old Sep 24, 2006 | 11:27 PM
maxxm's Avatar
Agreed. And I can tell you that the summer pavement in Arizona can get very, very toasty indeed -- often 30 to 40 degrees hotter than the ambient air temperature, which isn't particularly cool to begin with.
55chevy
Jul 22, 2024 02:31 PM
RED DOG
44
Oct 27, 2020 09:00 PM
TerryR
Dec 13, 2019 03:27 PM
Oct 1, 2015 01:42 AM
ayebb
Sep 18, 2015 03:35 PM
