Shift Knob
Old Oct 28, 2006 | 01:08 PM
Question Shift ****
I've been looking around for a shift **** for my auto-stick. The XF does not have a push button to shift from Parking. My question is than, should I be able to buy a **** that's made for a stick? Has anyone done this? Here's one of the ***** I'm looking at.
http://cgi.ebay.com/ebaymotors/aw-cg...m=190036732438
Old Oct 28, 2006 | 01:38 PM
blacklimitedcoupe's Avatar
Default Re: Shift ****
I believe you are correct...I think the bottom part of the shift **** unscrews and then there should be a set screw holding the **** on. I could be wrong, but any manual shift **** with the same inner diameter should work. That MOMO **** looks nice.
Old Oct 28, 2006 | 04:03 PM
Irafatsar's Avatar
4 is the my choice.
Old Oct 28, 2006 | 04:05 PM
Irafatsar's Avatar
Originally Posted by Irafatsar
4 is the my choice.
no wait 3 yea that's it.
Old Oct 28, 2006 | 08:18 PM
SRT SIX's Avatar
FPMartinez,
To change the **** on the autostick (not sure if it is the same on the manual) unscrew the ring on the bottom of the ****, let is slide down on the shaft an pull the **** off (straight up). The problem with most aftermarket ***** is that they do not let the shaft penetrate far enough. As a result the replacement sits about two inches higher (totally unacceptable).
You might want to do an eBay search for replacement ***** for an SLK. I got one for my SRT that is Walnut and black with an AMG plate but there are many others.
Valk
Jul 12, 2021 09:49 PM
crossfireusa
Oct 28, 2015 12:03 AM
jimf
Oct 10, 2015 10:22 AM
Crossfireone
23
Aug 25, 2015 04:56 AM
Cuda56
Aug 11, 2015 12:11 PM
