Re-program computer
Old Nov 17, 2006 | 08:41 PM
aptiva's Avatar
Default Re-program computer
I've read several posts concerning disconnecting the battery for a couple of minutes to allow the computer to learn the drivers driving habits. I bought my car with 5,000 miles on it and was wondering if that is worth trying. I'm sure someone has done this, and I wonder if it really did feel differently than before. I know I can't hurt anything by disconnecting, but if there is a negligible change I wonder if it's worth it. Thanks.
Old Nov 17, 2006 | 09:11 PM
CrossfireLTD's Avatar
Thumbs up Re: Re-program computer
This was posted by one of our members (HDDP I believe):
Throttle Body Adjustment. They say this works on all drive by wire vehicles and resets parameters WITHOUT Having to disconnect battery!
The Throttle is "Drive By Wire" and adapts to your particular driving
style. Do a TBA Throttle body adaptation.
1. Get in your car, it doesn't matter if you close the door or not.
2. Turn the key to the on (not start) position, the position just before the starter
turns over.
3. Press the gas pedal to the floor with the key in the "on" position.
4. Hold the pedal to the floor for five seconds, then turn the key back
to the "off" position (don't remove the key), then release the gas
pedal.
5. Wait 2 mins. for a full alignment.
6. Drive the car as you always do.
Depending on your driving style, this may or may not be a big factor. I do a lot of city driving so
I noticed a big change after erasing my history. It is not hard to do this, just follow the instructions -
Key on, pedal down, 5 sec, key off pedal up, wait 2 minutes.
Keep the key in for the entire thing.
If this doesn't work, disconnect your neg. battery cable for 20 minutes. This will re-set the parameters in the drive-by-wire... Unfortunately it will delete your pre-set radio stations, clock etc. as well...
Old Nov 17, 2006 | 10:22 PM
rdotson's Avatar
Default Re: Re-program computer
...And, then install a SprintBooster!
RED DOG
-C-I-C-C-I Discussion
Oct 8, 2015 09:28 AM
suelo
Sep 18, 2015 05:01 PM
Bayukbros
Aug 28, 2015 08:59 AM
scheper
Aug 3, 2015 03:13 PM
JEFASOLD
Jul 15, 2015 02:32 PM
