Crossfire Transmission Fluid?
Old May 2, 2011 | 01:32 PM
tighed1's Avatar
Default Re: Crossfire Transmission Fluid?
Originally Posted by silverfish1
thanks but im not getting any answers to my questions-
seems like any work that needs to be done on this car is a pain in the ***,
MORE info HERE
Hint - (Click on the red HERE above)
Old May 2, 2011 | 03:40 PM
Thirteendog's Avatar
Drop the pan, you need to change the filter anyway. When you buy a filter it'll come with a gasket for the pan. If it's an automatic make sure you get the torque converter. Then make or order a dipstick and you're good to go. Take your time, and if I can do it you can do it.
Old May 2, 2011 | 06:05 PM
how long should the dipstick be 57 inches or 50 1/8 inches?
I do not know how long the dipstick is, how tall are you?
Down load the Crossfire Service Manual and read it, it is a good source of information. You are getting answers but you are misinterpreting what is said and that could be very damaging to your car.
The auto repair skills of the members on this forum vary a lot, there are those that cannot do their own service, to those that can strip the car, throw all the parts into one box and then reassemble it with no problem.
Before you pick up a wrench you have to decide what your own level of proficiency is on the repair at hand. You obviously are keen to tackle the job so read and understand the requirements before you start. Remember that it is a steep learning curve for some, so take your time and understand each step.
Good luck, I'm sure you will do just fine.
Old May 3, 2011 | 11:41 AM
silverfish1's Avatar
Banned
Unhappy Re: Crossfire Transmission Fluid?
ok i need to know what type of trans fluid i can use on my crossfire
the owners manual says 236.1 236.2
Mobil One 1 now has transmition fluid that reads MB 236.1 & 236.2
Will this work?
Any thoughts?
Old May 3, 2011 | 11:44 AM
Banned
Tourq converter? what
i was told to just get a new filter and the sealer that copmes with that. are you telling me i need to buy more parts to do a Trans change?
Cmon guys wtf
Old May 3, 2011 | 12:28 PM
Cmon guys wtf
get meaning don't forget to open the drain on the torque converter. Sorry for the confusion.
Old May 3, 2011 | 12:44 PM
This car has one?
Old May 3, 2011 | 01:00 PM
If it's an automatic it does
Old May 3, 2011 | 01:15 PM
Not all autos have this.
I do not have an auto so I have not looked. I will now though.
Old May 3, 2011 | 01:18 PM
Banned
Now im beeing told to open the drain on the tourq converter?
All im doing is changing the transfluid, and replacing the Trans filter and seal
why do i need to mess with the converter
PLEASE EXPLAIN WHY I NEED TO DO THIS NOW
Old May 3, 2011 | 01:27 PM
There is no drain on this torque converter from what I can see, you change oil and filter only.
Look at the manual and check if you like.
Old May 3, 2011 | 01:33 PM
You asked for help. I gave you the answer, you drain the torque converter because it's got Transmission fluid in it.
All I was trying to do was help, no need to get angry. Do what you like and **** it up for all I'm concerned. I guess next you'll want us to tell you what the proper torque is for all the bolts on the trans case. You could just check the service manual like many of us have :/
Old May 3, 2011 | 01:39 PM
From what I'm seeing there is no drain plug in the TC. To drain it the system is drained, refilled and the line at the rad opened, the engine put in gear and the fluid is pumped out, when you see new fluid stop the car and reconnect the line to the rad.
This is probably not required unless you have high miles and burnt fluid, but it is a thorough job.
Old May 3, 2011 | 02:00 PM
I don't understand why you feel the need to argue with me? I've done this job, I think I would know???
Now it’s time to drain the torqueconverter (TC).
  • Remove the plastic cover from below the TC and see if the TC drain bolt is there (It’s not). To get the TC bolt at the bottom you will need to put the trans in neutral and either use a screwdriver to rotate the TC or use the 27mm socket and wrench to turn the engine (crank bolt, clockwise only please) until the drain bolt appears.
  • Remove the TC drain bolt with the 5mm allen wrench. NOTE: you would be wise to fashion some sort of device to help the fluid find its way into the drain pan. Its gonna be MESSY!
  • Reinstall TC drain bolt.
Old May 4, 2011 | 08:11 AM
ChuckNorris's Avatar
Mine had no drain on the TC. Having a drain on your TC is apparently very rare for the crossfire. You are lucky if you do have a drain and the first I have heard of.
Old May 4, 2011 | 01:03 PM
Banned
Chuck norris Rules!!!!
Im lifting my 04 Xfire (Atomatic) this sat, to drain the Trans fluid and replace the Filter
some peps say drain the converter as well, AGAIN i get mixed answers to my question, some say this car has a drain plug some say it does not.
Either way once i am done i will post THE CORRECT information one needs to complete this job,and the location of where the Trans drain is located.
Next
roland1226
Feb 26, 2019 10:19 PM
vspuds
Oct 11, 2018 05:16 PM
BibaResto
Nov 7, 2016 08:21 AM
MJPowers
Jun 8, 2015 02:34 AM
adamlevy
Jun 7, 2015 08:13 PM
