Crossfire Transmission Fluid?
Old Feb 13, 2007 | 07:50 PM
kaeXo's Avatar
Default Crossfire Transmission Fluid?
Hey guys kind of stupid question, but I was wondering how to put in Transmission fluid, like where its located, etc.
Old Feb 13, 2007 | 08:50 PM
Maxwell's Avatar
Default Re: Crossfire Transmission Fluid?
I'm sorry but I have to laugh, hahaha. Look for the red dipstick, near the firewall.
Old Feb 13, 2007 | 09:00 PM
marauderroy's Avatar
Be nice.
Sorry to tell you but there is no way to check or add tranny fluid to a Crossfire. Read your owners manual. If you want to change the fluid you'll have to take it to a dealer.
Old Feb 13, 2007 | 09:58 PM
Maxwell's Avatar
lol, guess that's why i could never find mine either.
Old Feb 13, 2007 | 10:01 PM
MMZ_TimeLord's Avatar
There is no dipstick. If you look at the service manual it will show you a plug that can be pulled for filling. But, without a dipstick, you are just guessing.
The idea is that if you have to add fluid... it's got a problem and should be serviced not just continue leaking.
Old Feb 13, 2007 | 10:17 PM
VQ35DE's Avatar
For you guys that have been under your cars, does the automatic transmission have a DRAIN plug in the bottom of it?
Old Feb 14, 2007 | 01:11 AM
I don't believe it does... my pan seal had to be replaced at the dealer and I think they had to simply take off the pan to drain it... but I'm not positive.
Old Feb 14, 2007 | 01:21 AM
+fireamx's Avatar
This "no transmission dip stick" issue must be a "German" thing. When I got my Wife a VW Beetle back in 1998, the owners manual said there wasn't any dip stick on the auto version of it either.
That was the first time I had ever heard of such a thing.
Hey Andrew, does your Bimmer have one?
Old Feb 14, 2007 | 09:15 AM
Iamfink2's Avatar
The crossfire service manual shows there is a drain plug for the transmission.
Old Feb 14, 2007 | 09:21 AM
VQ35DE's Avatar
Even for the Auto Trans, correct?
Old Feb 14, 2007 | 09:33 AM
Iamfink2's Avatar
According to the service manual there is a drain plug for the automatic tranmission. Its in section 21-211. If you do a search its available for download on the forum.
Old May 2, 2011 | 09:26 AM
silverfish1's Avatar
Banned
Angry Re: Crossfire Transmission Fluid?
then where is the trans drain plug located at?
Old May 2, 2011 | 09:29 AM
Banned
Unhappy Re: Crossfire Transmission Fluid?
you put in the fluid from the top of the engine, look for a black **** with a red plastic clip/lock located next to the firewall of the engine, thats where you fill the trans fluid
Im looking for the trans fluid bolt/nut to drain ?
Old May 2, 2011 | 09:49 AM
MikeR's Avatar
Look in the service manual starting on page 21-307 for the description of the transmission dipstick cap & lock. You can buy a dipstick($$$$) or use a heavy duty zip tie like Woody documented.
My car is not here right now so I cant go take a pic of the drain plug. It should just be on the bottom of the pan and easy to find.(assuming you know which part is the transmission) Be sure to replace the drain plug seal when you re-install it. The service manual gives fill levels based on temp of the transmission fluid.
Old May 2, 2011 | 10:08 AM
tighed1's Avatar
Drain bolt is a 5mm allen head.
Mine was in VERY tight! Had to use a small pipe on the allen wrench to bust it loose.
Woody's dip stick trick is HERE.
Old May 2, 2011 | 11:11 AM
Banned
how long should the dipstick be 57 inches or 50 1/8 inches?
Old May 2, 2011 | 11:24 AM
Banned
drain plug seal? Is there not a seal already on the car or will i need to buy another one?
Old May 2, 2011 | 11:41 AM
Banned
how long should the transmition make shift dip stick be (and how long should the measurements be on the makeshit dipstick so i make sure i have a correct reading if its to low or to full?
You mentioned the drain bolt is 5 mm, im very nervose i might strip this since its on so secure, and do i need to put the car in N to get to the drain bolt or will it be visable once im under the vehical?
Old May 2, 2011 | 12:01 PM
IBLUBYU's Avatar
Geez .... go back to post #15, and click on HERE. There is a post in that tread that will answer all your questions..
Old May 2, 2011 | 12:13 PM
Banned
thanks but im not getting any answers to my questions-
seems like any work that needs to be done on this car is a pain in the ***,
