BAS ESP light - ABS Module
Old Nov 1, 2013 | 08:09 PM
jayswagger908's Avatar
Default Re: BAS ESP light - ABS Module
Originally Posted by rrodea
Hi guys!, I have a problem with my xf '04, I have the BAS ESP light on, The dealer said that is the ABS module and I need replace it, the part number is 05140827AA. somebody told me that I can buy the part and plug it by myself, do you know if there is a guide or something to do it?
Antecedents: The BAS ESP light was on some days ago but I stopped the car turned the engine off and started again, the light did not come on. The next day the light was on again to run some miles I repeated the procedure, also the light go off, same day, but in the next trip I was driving my car slowly because the traffic then all the lights was on and the engine stopped. I started it immediately and the BAS ESP light was on.
I took my xf to the dealer and the did not found anything, the scan said all was ok, so i got back my xf normally, the next day in the first trip the light was on and I took my car to the dealer with the light on, then they made the diagnostics and that seems to be a sensor in the wheel, but they took another day to certify the diagnostics, but finally they to told me about the module; 05140827AA.
I have to say that the dealer forgot to reset the maintenance program after the last service. So my doubt is; Can the module failure cause the car stop?
Any help will be appreciated. Thanks in advance.
Ricardo
the problem is your abs module you have 3 options to fix
1. replace at dealership around $1,900
2. order an new abs module on a mopar web site around $800
3. replace with a used abs module $ 250
I replaced with a used one and it works fine you can buy at a local junk yard or on ebay
you can do it yourself its plug and play no reprogramming involved
Originally Posted by Redalert
This spring I was driving my '04 Xfire and suddenly the speedometer went to zero, the rear spoiler went up, the car dropped into low gear and most of the car's warning lights came on.
The first suggestion I had from a Chrysler service person was a low battery. That was replaced and same issue.
I had the Xfire hauled to the dealership some 20 miles away on May 5. Diagnosis is the ABS controller. It has been on backorder with about 2 week updates being offered. Yesterday the expected due date was moved to October. I secured the part number from the parts department and may have located a couple of places that have the part. Dealership said the cost of the part would be $1000 but the part listed on the other sites were both $199.
It's been almost 2 months and no Xfire! Dealership called today to see if I was interested in trading it in and they offered to make the trade in value as in "running condition." I haven't pursued that at this time.
Old Nov 2, 2013 | 10:56 AM
JimmyJames's Avatar
Get that car out of the dealership---and save money.
People on here run circles around the dealership. Actually, they should just log on here and get these cars fixed QUICK---Good luck. Jimmy
Old Nov 2, 2013 | 11:03 AM
I doubt the car is still in the dealership, this thread is 3+ years old.
Maybe the dealership has gone as well.
That was Redalerts last post so maybe he traded the car.
pioneer4x4
Mar 25, 2019 10:35 AM
Hoppy
Dec 7, 2018 07:36 AM
northwest_crossfire
May 30, 2016 05:19 PM
xfClifford
27
Nov 10, 2015 10:08 PM
Blackout317
Jul 7, 2015 08:38 PM
