Crossfire Control
Old May 3, 2007 | 04:40 PM
Arcrist's Avatar
Default Crossfire Control
So I know the xfire has traction control and stability control... but i'm not sure which one does what exactly.
One shuts down the throttle when you lose traction, and the other brakes certain wheels or something?
Do all of you guys disable these controls? I noticed one time when I took a sharp turn and gassed it, I almost wrecked because I expected certain physics to come into effect.
Old May 3, 2007 | 04:49 PM
Romio's Avatar
Default Re: Crossfire Control
TC is what happened when your wheels spin, It can put power until you regain traction. Stops you from spinning your wheel. ESP stability control keeps your car straight while driving. for example in the snow, if you start to fish-tail it might brake, cut off gas. I leave my TC on because it rarely jumps in. You can turn the TC off, but not the ESP. If you want to do a burn-out turn TC off. leave it on or off for drag racing, depending on how you launch, because if you spin and it kick in you will kill your time because it slows down the gas.
Old May 3, 2007 | 04:56 PM
Arcrist's Avatar
Keeps the car straight while driving? Maybe its the damn roads around here but im always pulling to one side or another. Tires are inflated properly.
Old May 3, 2007 | 04:57 PM
Romio's Avatar
I meant in the snow or rain if you start to lose control. And most crossfire pull if the road it sloped to the side much, or there are grooves.
Old May 3, 2007 | 05:03 PM
AMGLover's Avatar
Deleted Message
Old May 3, 2007 | 05:44 PM
Arcrist's Avatar
closet? are you implying that i'm gay?
Old May 3, 2007 | 07:41 PM
AMGLover's Avatar
Deleted Message
Old May 3, 2007 | 07:54 PM
SpaceManSpiff's Avatar
Originally Posted by Romio
TC is what happened when your wheels spin, It can put power until you regain traction. Stops you from spinning your wheel. ESP stability control keeps your car straight while driving. for example in the snow, if you start to fish-tail it might brake, cut off gas. I leave my TC on because it rarely jumps in. You can turn the TC off, but not the ESP. If you want to do a burn-out turn TC off. Leave it on or off for drag racing, depending on how you launch, because if you spin and it kick in you will kill your time because it slows down the gas
The owners manual says that you can turn the ESP (Electronic Stability Program) off/on, not the traction control.
Old May 3, 2007 | 08:19 PM
Originally Posted by AMGLover
New wardrobe...hello Mr. short attention span...date, black tee...shhesh don't go all homophobic on me!
Not that there's anything wrong with that.
Old May 3, 2007 | 11:13 PM
AMGLover's Avatar
Deleted Message
Old May 4, 2007 | 08:14 AM
gibsonjunkie's Avatar
The traction contol on the Crossfire is ten times better than it was on my last Mustang. That kicked in all the time (at the wrong times). I almost never see it come on now.
Old May 4, 2007 | 12:50 PM
bigpapapuff's Avatar
Talking Re: Crossfire Control
I did a dumb one on the way to the job the other morning... I was driving on our access road and looking at something that was going on at the project that I did not care to be seeing (and not paying enough attention to my driving) and my right side tires went off the road and into the gravel. I corrected and the ESP did the rest. Let me tell you, the stuff works great! If not for that, I would have done a 180 pretty darn quick. I only driving about 30 mph and was the only one on the access road at that time of the morning like usual (5:15 am) so it was no big deal, but it sure got my attention. So my advice from learning the hard way, leave the stuff on. But if you like to do burn outs, you can turn off the traction control.
Frankenmerc
20
Dec 13, 2025 11:51 PM
MJPowers
Jun 8, 2015 02:34 AM
WindRestrictor
Jun 1, 2015 02:31 PM
bourbonton
May 31, 2015 09:57 PM
bourbonton
May 29, 2015 02:51 PM
