Can I jack this thing up by the diff/crossmember ?
Old May 5, 2007 | 04:17 PM
Cincinnati Slim's Avatar
Default Can I jack this thing up by the diff/crossmember ?
Howdy All,
Can I safely jack either end of a Crossfire up with a big 'ole floor jack ?
You know stick it under the front crossmember or under the rear-end and jack up one end of the car at once ? I previously had a '97 Cougar with rear IRS and the diff was mounted on rubber bushings so you could not put a jack on it without tearing up the bushings. The front crossmember also seemed a little thin to use to jack up the whole front end of the car. I'm used to old Mopars with massive "K" members in front and solid axles in the back. It sure is handy to be able to get one whole end of the car up in the air at once. I'll be installing the new Magnaflow exhaust myself so I need to get the butt end of the car up high enough to do the work.
Thanks.
Slim
Old May 5, 2007 | 04:56 PM
AMGLover's Avatar
Default Re: Can I jack this thing up by the diff/crossmember ?
Deleted Message
Old May 5, 2007 | 05:21 PM
bigpapapuff's Avatar
Talking Re: Can I jack this thing up by the diff/crossmember ?
Originally Posted by Cincinnati Slim
Howdy All,
Thanks.
Slim
Here is a term I use sometimes with the guys that work for me. Pretty plain and simple,"If you do it, that would be a really, really bad thing." They usually get the point, usually. If they don't then they will end up with a new job some place else.
Old May 5, 2007 | 07:11 PM
crossfirefun's Avatar
Default Re: Can I jack this thing up by the diff/crossmenber ?
I jack the front of mine from the center but never the rear.
Old May 6, 2007 | 06:12 AM
MMZ_TimeLord's Avatar
The front crossmember is probably stout enough to handle the weight without twisting or misaligning anything. The rear has no central jack point to speak of.
Personally, I will stick with jacking up one of the front sides first (front jack point), use a stand, and then jack the other side. It's just safer and this car is more than stiff enough to handle the torsion.
rmcdaniel12
Nov 4, 2015 04:08 PM
Oct 1, 2015 01:42 AM
Sep 28, 2015 07:40 PM
debradegiovanni
Sep 27, 2015 09:39 AM
ritous1
Sep 26, 2015 01:27 PM
