clay bar?? can someone explain
Hey forum - sorry if this question has been answered a billion times haven't been here in a while. I have a '05 limited coupe aero blue pearl color and ever since I moved out to Az my car seems to never look as good as when it was new from dealer. I wash wax and it still doesn't have that high polish. Someone suggested a clay bar not exactly sure how to use that, can someone please help with a step by step do I wash clay bar wax? Not really sure any advice and tips as I want my car to have that new car shine to it?
Re: clay bar?? can someone explain
I am not a car washing expert, but as far as I understand...
A clay bar removes stuck on pollutants on the clear coat that make the paint feel rough...embedded crap, and when you wax, you are not getting a good wax to paint contact.
The clay bar, sold in a kit usually, used with a lubricant such as McGuires quick detailer, runs across the clear coat surface and removes the embedded crap and leaves the paint feeling like glass. Then, when you wax, the wax adheres to the surface much better.
I spray a 1'x1' area with the lubricant, rub the clay across the surface, and then wipe clean. I usually work the clay to make sure I don't rub the same dirt on the clean areas.
I also hear you shouldn't clay too much, maybe 3 times a year.
Andrew, golfdude, and others are experts on this however, and there are many other threads regarding this issue.
<--- Huge Horsepower
on
Clay Bar shears-off contaminants leaving a silky-smooth surface. Easy to wax and shine.
I suggest you buy just the clay-bar has the lubricant in the McGuire’s kit is just expensive candy smelling "Show Shine" when all you need is water. Save a few $$.
I recommend it.
I recommend it.
Originally Posted by xxfirerican
so i wash, use the clay bar with a wax detailer then wax after that ?
~ wash
~ clay
~ wipe down complete car with quick detailer using a micro-fiber towel
~ polish surface (i prefer 3M hand glaze)
~ then wax with a canuba quality paste wax... meguiar's
hope this helps.
on
Originally Posted by CrossfireLTD
If the paint is not seriously contaminated, I have found that the Ice Clay Liquid Clay Bar works well and is very easy to use. I would suggest to follow Andrews instructions and use the Clay product that is best suited.
Here is a good web site "how to" look after a car. They do sell products but I have found the information very helpful. (wrt to clay bars - be very careful).
http://www.carcareonline.com/howto.aspx
http://www.carcareonline.com/viewarticle.aspx?art=5
http://www.carcareonline.com/viewarticle.aspx?art=0
on
1 Post
Here is a clip from Adams on how to clay bar, i use their products very happy with them.
http://www.adamspolishes.com/t-videos_clay_bar.aspx
2005 Ragtop
10-03-2015 03:01 PM
