fuel filler compartment flood
Old Jul 12, 2007 | 03:41 AM
Mediacritic's Avatar
Default fuel filler compartment flood
Hey,
We just had a torrential rainstorm. When things dried up I took a spin to get gas. I popped open the fuel filler door to find quite a puddle in the compartment. I soaked it up with some rags I keep in the car for polishing. There seems to be a drain - at least there's some kind of hole beneath the gas cap which I figure must be a drain. Never had this happen before. Maybe it got plugged somehow?
Old Jul 12, 2007 | 07:03 AM
bobs's Avatar
Default Re: fuel filler compartment flood
Sounds like a plugged drain for sure. You can probably blow it clean with a bit of compressed air.
Old Jul 12, 2007 | 11:18 AM
DAMNFINO's Avatar
Don't know your location, but down here in the country the mud daubers (insects) plug about every small overflow, drain line, or vent on the tractors, four wheelers, motorcycles, etc. I found it to be a good idea to check these items frequently in the summer. They even plug up the mufflers on weed eaters and chain saws.
Old Jul 12, 2007 | 12:13 PM
Gross! Summer is great, but insects suck. I'm in NH and there are tons of annoying ones, but not those. Thanks.
Old Jul 12, 2007 | 04:49 PM
Sandgrounder's Avatar
The drain exit is about 4 inch's behind the rear tire, 1/4 tube.
Old Jul 13, 2007 | 01:32 AM
Thanks for the tip.
Old Jul 15, 2007 | 05:30 PM
BullFrog's Avatar
The drain tube sometimes can easily be seen from underneath the car if its pulled out a lot however be it that its so close to the huge rear tires grime. The dirt usually kicks up and plugs it. I had mine pushed upwards toward the hole in the well and that prevents any clogging as its tucked up. Easy FIX though.
Old Jul 15, 2007 | 08:39 PM
andrew's Avatar
-C-I-C-C-I Associate Member
here is a pic...
Old Jul 15, 2007 | 08:43 PM
Cyril Baldwin's Avatar
Andrew, you failed to put Armor All in your drain plug...lol!
Old Jul 15, 2007 | 10:13 PM
midnightman's Avatar
Originally Posted by andrew
here is a pic...
Ya' know, I spent considerable time looking at this picture in hopes of finding a small bit of dirt to make fun of, and could not. (Tire treads don't count. Even for Andrew).
I mean, it's the frikkin' underside of the car! I don't know whether to be impressed or frightened.
Old Jul 15, 2007 | 11:35 PM
andrew's Avatar
Talking Re: fuel filler compartment flood
... LOL ...
not bad for being driven in the rain... snow... and at 37,000 miles...
i try my best.
roar
Jun 15, 2022 11:46 AM
rampntlion
21
Feb 11, 2019 08:18 AM
berklund
15
Sep 19, 2016 03:14 PM
RacerXofFL
Sep 15, 2015 05:00 PM
81's
Sep 13, 2015 04:34 PM
