Autostick manual shifting
Old Sep 7, 2007 | 09:17 AM
rock's Avatar
Default Autostick manual shifting
Hey guys. Just a quick question about the Autostick. When shifting, do I need to take my foot off of the gas? Would I be doing any damage if I didn't remove my foot when shifting?
Old Sep 7, 2007 | 09:24 AM
andrew's Avatar
-C-I-C-C-I Associate Member
Default Re: Autostick manual shifting
no need to lift.
also a neat feature... if you hold the shifter to the left (while moving)... the car will down shift in to the lowest gear possible for best acceleration.
Old Sep 7, 2007 | 12:23 PM
As a matter of fact, if you forget to shift or are not quick enough, it will shift automatically right before you redline. Aren't computers wonderful?
Old Sep 7, 2007 | 01:10 PM
AimeeJ's Avatar
Nope. My fiancé loves it, but I only use it to pass slow drivers/annoying teenagers.
Old Sep 7, 2007 | 02:00 PM
MMZ_TimeLord's Avatar
I don't even shift anymore... The transmission has learned my habits and will even hold gears in the corners at the track.
The Auto-Stick in these cars are VERY intelligent.
Old Jan 22, 2008 | 12:49 PM
cgocifer's Avatar
In standard auto mode, do we have to hit the switch on the floor to get the car to shift into the next lower gear? It seems as though that's what needs to happen in my car. Again, this is in automatic mode. If I don't mash the pedal to the floor to actuate the switch, it stays in the gear I'm in and is sluggish (obviously because the revs are low).
Old Jan 22, 2008 | 02:47 PM
bflinn's Avatar
Originally Posted by andrew
no need to lift.
Also if held to the right - automatically goes back to D drive into fully auto mode......does that equate to neat X2 or neat too or too neat or....oh well, I digress....
Old Jan 22, 2008 | 03:07 PM
V-12's Avatar
old post I know but is that really true? you mean your car just stays in an "aggressive" mode?
Old Jan 22, 2008 | 04:46 PM
You shouldn't have to press the pedal all the way down to the floor and press the switch to downshift. Just a press on the gas past halfway will shift mine down a gear. If I press all the way to the switch and click it down it will shift to the lowest number gear for max acceleration.
Old Jan 22, 2008 | 06:06 PM
cgocifer's Avatar
Maybe I need to do a reset, because mine will not shift, no way no how until I mash it to the floor. :-(
Old Jan 22, 2008 | 06:58 PM
Ya I would try that drive by wire reset procedure and see if it changes anything.
I do have a sprint booster on my 04 but even before that it would downshift without a full to the floor throttle press.
Osusannah
Feb 12, 2024 01:49 PM
crossfireusa
Oct 28, 2015 12:03 AM
jimf
Oct 10, 2015 10:22 AM
eatmycrackers
Sep 23, 2015 09:08 AM
Selbyl
Sep 22, 2015 10:41 PM
