Drivetrain ratio???
Old Oct 16, 2007 | 04:09 PM
Gasi Jr's Avatar
Default Drivetrain ratio???
Does anybody now what drivetrain ratio is in the crossfire? Same in srt?
Old Oct 16, 2007 | 05:23 PM
old man's Avatar
Default Re: Drivetrain ratio???
i think they are both 3.25
Old Oct 16, 2007 | 05:29 PM
BLACKSRT-6's Avatar
That is correct and I was told by a Mercedes Dealers parts manager that no other gears are available to change the ratio.
Old Oct 16, 2007 | 06:08 PM
+fireamx's Avatar
Actually it's 3.27:1 in the Limited and Base cars, and 3.07:1 in the SRT6.
Both are "open" of course.
Old Oct 16, 2007 | 06:26 PM
old man's Avatar
my mistake 3.07 on the srt6.
Old Oct 16, 2007 | 07:39 PM
ShawnQ's Avatar
And someone FINALLY found a limited-slip for the rear differential of the SRT6, which means it will likely work in the NON-SRT if they use the same axle...do they?
SQ
Old Oct 16, 2007 | 07:50 PM
+fireamx's Avatar
Originally Posted by ShawnQ
And someone FINALLY found a limited-slip for the rear differential of the SRT6, which means it will likely work in the NON-SRT if they use the same axle...do they?SQ
I assume they do, but I don't know why you would need it in a non-SRT car.
Even when I launch hard in my 6-spd, I barely spend much time spinning my wheels. It always "hooks up" real good.
Old Oct 16, 2007 | 07:55 PM
04Fire's Avatar
And someone FINALLY found a limited-slip for the rear differential of the SRT6...
Where'd you find that out? Pics/Specs?
Old Oct 16, 2007 | 09:47 PM
LantanaTX's Avatar
See thread for Phantom LSD.
rfourt
Sep 25, 2015 01:38 PM
blackpepper
Aug 31, 2015 12:18 PM
perceptionproblem
Aug 8, 2015 06:15 AM
SLK32Germany
Mar 22, 2008 07:00 PM
NeverEnough
Racing
Aug 8, 2007 08:01 AM
