Windsheild Washer Reservoir capacity
Old Dec 4, 2007 | 12:21 PM
62thunderbird's Avatar
Default Windsheild Washer Reservoir capacity
I went to fill the reservoir and it filled to the top of the neck. Then it proceeded to drain out onto the ground behind the front wheel in a nice clean stream. But it did not totally drain the reservoir. So my question is, is there an overflow tube or something limiting the capacity? or do I have a crack in the reservoir?
I tried to check, but it appears that they hung this part from a string and built the car around it. I do have the warranty to fall back on, but figured someone here may have info.
Old Dec 4, 2007 | 12:29 PM
Iamfink2's Avatar
Default Re: Windsheild Washer Reservoir capacity
There's an overflow.
Old Dec 4, 2007 | 01:04 PM
spensley's Avatar
Stop pouring when it appears on the ground - by that time you will have wasted about a liter!!!
Old Dec 4, 2007 | 06:08 PM
My '04 does the same thing. There is an overflow somewhere on the tank and this prevents you from overfilling the tank. Just fill it until you notice the spillage.
PNA
Nov 12, 2020 04:44 PM
Sep 26, 2015 10:21 PM
Ralph289
Jul 26, 2015 12:52 PM
shawnwatson9493
Jul 9, 2015 11:47 PM
Steve Hellums
26
Jan 22, 2007 04:29 PM
