Fuse blown
Old Jan 6, 2008 | 11:58 PM
Sarx's Avatar
Default Fuse blown
Hi guys. Sorry for posting here, but I dont know where to post this. I switched on the radio yesterday and found that there was no audio. I opened up the fuse box and saw that the amplifier's fuse was blown. I took a spare 15A fuse and when I put it in, it made sparks. Should I have taken off the negative battery terminal before doing this or can anything else be wrong?
Old Jan 7, 2008 | 12:28 AM
GDC-SRT's Avatar
Default Re: Fuse blown
Did the new fuse burn out as well? If it did, try turning the radio off first. There must be a short in the circuit at some point, before or in the radio itself.
Good luck
Old Jan 7, 2008 | 01:09 AM
Sarx's Avatar
Thanx for the reply GDC. The radio and ignition was switched off. The new fuse burnt out when I tried installing it when it sparked. Does anyone know if I should disconnect the battery before installing a fuse?
Another q, in the service manual it mentions a power amp harnass connector. Where is this located?
Old Jan 7, 2008 | 07:52 AM
sonoronos's Avatar
No, you do not need to disconnect the battery before installing a fuse.
If the fuse blew as soon as you put it in, there is a short circuit somewhere. Did you have an aftermarket stereo put in?
Also, do you have a limited/srt-6 or a base?
Old Jan 7, 2008 | 10:50 AM
Sarx's Avatar
Standard infinity radio that came with my Coupe LTD...
Old Jan 7, 2008 | 12:46 PM
sonoronos's Avatar
Section 8A-20 in the Service Manual has removal instructions for the Amplifier. It's under the passenger footwell.
I would start by checking continuity to all wires to hot/12+
Old Jan 7, 2008 | 10:18 PM
Sarx's Avatar
Thanx sonoronos. I'm going to check it tonight when I get home.
Does anyone know where the most likely part in the wiring harnass a short could have occured? A place with the most wear perhaps?
Old Jan 25, 2008 | 04:09 AM
Sarx's Avatar
So I took my XF in for a service and they couldnt find the problem. They said they'll have to have the car the whole day to strip out the seats, carpets, dash etc. The mechanic asked me if I had a satelite tracking device installed becasue it can give problems in the wiring. So I went to Tracker (the sat tracking place that installed my unit) and had them check it out. Now my radio's working again! Ha!!
Old Jan 25, 2008 | 04:43 AM
apkano's Avatar
Life is random...so am I.
Sounds like someone pulled power from somewhere they shouldn't have.
Old Feb 5, 2008 | 02:58 AM
Sarx's Avatar
AAAarrrggghh! It happened again!
I'm taking my car in. Will let you guys know what the problem was...
Old Feb 19, 2008 | 05:00 AM
Sarx's Avatar
It was a 4amp wire behind the centre console that was scuffed through. Fixed
usprb1976
Apr 4, 2024 04:57 PM
northwest_crossfire
May 30, 2016 05:19 PM
Reliableron
Oct 17, 2015 10:19 PM
Selbyl
Sep 22, 2015 10:41 PM
Bob4kacz
Sep 16, 2015 11:20 AM
