Supercharger?
Old Jan 15, 2008 | 10:35 PM
addie18's Avatar
Question Supercharger?
I was wondering if you could put a supercharger on a regular 6spd coupe? If you can
I would like to know what it might cost because I would like to within the next cople of months.
Old Jan 15, 2008 | 11:26 PM
sonoronos's Avatar
Default Re: Supercharger?
https://www.crossfireforum.org/forum...ann+kompressor
Get some heart pills handy.
Old Jan 15, 2008 | 11:38 PM
CrossfireLTD's Avatar
Cool Re: Supercharger?
It would be cheaper and easier to buy an SRT6 Crossfire
Old Jan 15, 2008 | 11:52 PM
04chryslr's Avatar
yes, but if he is like me, its terror driving an automatic, no offense
Old Jan 16, 2008 | 12:35 AM
bobs's Avatar
This has been discussed ad nauseam. Do a search.
Old Jan 16, 2008 | 03:40 AM
infared12's Avatar
I second that automatic comment.....I think its so boring driving an auto with the crossfire!!!!
Old Jan 16, 2008 | 07:22 AM
62thunderbird's Avatar
Sorry if this is considered threadjacking...
I think the manual, while fun, could have been so much better. First is too low and the shift to second is too notchy (is that a word?) for my taste. I'm on my second shifter mechanism and I still wish it were a smoother system. And sixth could be more of an overdrive for highway use.
If you don't make sure the shift to first is completely engaged, it will pop out. That, in itself, is no surprise but the noise it makes is ungodly. Sounds like the tranny disintegrates.
If I ever get another one, I'll go for the auto.
Old Jan 16, 2008 | 08:01 AM
sonoronos's Avatar
62thunderbird,
There's a TSB with your name on it. Under warranty? Get it fixed! The 6MT should be flawless - the 1st gear popout issue was solved 3 years ago...
Old Jan 16, 2008 | 08:55 AM
apkano's Avatar
Life is random...so am I.
I need to find a new, updated way to say....."here we go again! "
Don't let HDDP see this thread......he has a pretty good method for telling people to use the search feature of the forum.
Old Jan 16, 2008 | 11:26 AM
xfire2005's Avatar
Originally Posted by sonoronos
62thunderbird,
The MT in my Crossfire is flawless, quiet and one HELL OF A LOT OF FUN!
Old Jan 16, 2008 | 11:55 AM
newCrossfire's Avatar
ive had this happen to me a couple times does this tsb also have somthing to do with the car not shifting smoothly even with draging the clutch?
Old Jan 16, 2008 | 12:09 PM
Shawnkey's Avatar
I barely us 1st. I use 2,4,5,&6th usually. nice and smooth
Old Jan 16, 2008 | 12:35 PM
Maxwell's Avatar
I would wait a couple more years for the car to depreciate further and let the Euro fall. pick up a nice used crossfire for about $8k, then purchase the Renntech kit for another $10k, might require $1k in tuning, so your in at about $20k you can have the manual 6spd and make 310hp with the low boost kit. it is upgradable to a high boost kit but then you've broken budget.
Old Jan 16, 2008 | 12:49 PM
sonoronos's Avatar
TBS: 9-Mar-04 - 21-002-04 - Manual Trans - First Gear Disengages During Normal Acceleration
As for your car not shifting smoothly even with dragging the clutch, I have to say that is abnormal. I don't have to drag the clutch at all anytime. This car has
Shifting as per the service manual:
HARD SHIFTING
Hard shifting is usually caused by a low lubricant level, improper, or contaminated lubricants. The consequence of
using non–recommended lubricants is noise, excessive wear, internal bind, and hard shifting. Substantial lubricant
leaks can result in gear, shift rail, synchronizer, and bearing damage. If a leak goes undetected for an extended
period, the first indications of component damage are usually hard shifting and noise.
Shift component damage, incorrect clutch adjustment, or a damaged clutch pressure plate or disc are additional
probable causes of increased shift effort. Incorrect adjustment or a worn/damaged pressure plate or disc can cause
incorrect release. If the clutch problem is advanced, gear clash during shifts can result. Worn or damaged synchro
rings can cause gear clash when shifting into any forward gear. In some new or rebuilt transmissions, new synchronizer
rings may tend to stick slightly causing hard or noisy shifts. In most cases, this condition will decline as
the rings wear-in.
gblack32
Sep 7, 2016 08:27 PM
zackman62
Nov 6, 2015 12:37 PM
UNDER PSI
Nov 1, 2015 09:39 PM
tom2112
Oct 26, 2015 08:18 PM
FiftyThree033
Jul 26, 2015 09:24 PM
