Windshield Washer Spray Nozzles don't spray anymore
Anybody experience this? that they just spontaneously stop??? Can windshield washer fluid freeze? It's only like 20 deg F today in MI. Maybe got down to 15 deg F at the lowest during the day. I can hear the pump going, but no juice. I added about 2-3 cups (measured) to the reservoir cuz that's all I had in the garage, and still nothing.
Any ideas?
Any ideas?
Re: Windshield Washer Spray Nozzles don't spray anymore
Originally Posted by Iamfink2
I was told by the Toyota dealership for my 4 runner I used to have always keep your resevoir full in sub freezing temps so the pump doesn't freeze and crack.
Here's and old link that probably explains your leak.
https://www.crossfireforum.org/forum...+fluid+leaking
Originally Posted by all_Bran
That's very intersting because when I went to put some fresh fluid in, I was curious as to why it was taking a whole 1Gal bottle... Until I heard the water falling. I look under the car and what looked like a whole gallon of fluid has leaked onto the floor. Is this normal? Is there an overfill something that just dumps fluid all over the ground??
Washer fluid can freeze in the nozzles of any car. It is a mixture of water and an alcohol (not safe for human consumption). If the washers have not been used in a while the alcohol may evaporate, leaving mostly water, which will freeze. Use a hair dryer or warm (not hot) water to melt the ice in the nozzles. Once you rince through some fluid that has a higher concentration of alcohol your freezing problem will probably resolve. Do not use very hot water as you could crack your windshield.
Dumb... But at least I know it works and I don't have to put even MORE money into this car...
Any ideas?
Any ideas?
i'm just glad I didn't crack the reservoir.
anybody have an idea on how much it's supposed to hold?? I didn't put much in before it started overflowing... Maybe 1/3 to 1/2 a gallon?
Originally Posted by Cross+Fire+06
once my light comes on .. i can put a full gallon in
The dealership put crappy fluid in and I'm sure that's why it froze... So when I put good fluid in, it probably melted the frozen stuff and started flowing.
all-Bran I had the same exact experience as you this past weekend and I also live in Michigan. I went to use the nozzles and nothing came out and no light was on so I figured it was low anyways, well it was close because I put in about 3/4 gallon before overflow but when I went to try it I had no luck still. I figure it was the extremly low temps we got here (~5 degrees) freezing up the nozzles or lines. I haven't needed to use it since but I'll check it later today, I'm waiting for warmer temps to hopefully unfreeze the lines.... Or the pump broke but I'm ignoring that possibility for now...
Any ideas?
Any ideas?
on
