Headlight burnt out! Urgh!
Where can i get bulbs other than the stealership? Murrays? AutoZone? I know it's probably very hard to install, but I just don't want to get raped for the bulb... It's the regular headlight bulb. Is that the projector bulb? Or is it a standard fillament-style bulb?
Isnt' it a projector bulb?? I fully believe you, Murrays confirmed it about 10 min ago for me... It just looks really weird. It really looks like a projector! (keep in mind, I've never owned a car with HID projector lights and dont' really know what it is/what makes it up/why it's different).
Thanks in advance!!
Thanks in advance!!
Thanks in advance!!
Thanks in advance!!
Originally Posted by strupgolf
The bulb is easy to install, about 20-30 minutes. I did mine; you just have to loosen a few things up around the area, pull out the socket from behind, install, and reverse.
Just like Strup said...about 20 minutes or less I have big hands and was able to do it fairly quickly. It's a tight spot and no you don't have to take off the fascia. Just a small cap over the back...disconnect plug...release tension spring...turn bulb counterclockwise and release....reverse for install making sure not to touch bulb with fingers(natural oils from hands shorten bulb life) It can be frustrating but it can be done!
Do you have a documented How-To on this? The dealership told me i had to take the entire fascia off!
Originally Posted by robby363
Off topic, but why does post #4 keep changing.
WTF? That's messed up.
Can somebody please take a picture and draw an arrow to what I'm supposed to unscrew? I'm used to my Neon's headlamps that are really easy to visualize. I'm not sure these are the same until I get it apart.
Any help figuring out which one I'm supposed to twist out, would be much appreciated. Thanks!
Sorry, I changed mine months ago. It seems there is a spring/clip typ attachment that holds the bulb holder to the case. You take this clip off, I dont know if you turn it clockwise etc. or not, but you pull the holder towards the rear where you will see the bulb. Pull the old bulb out and put new one in, dont thouch the bulb. Hope this helps, if not let us know, I'll go out in the morning and get better instructions, its cold out there.
You can change it from under the hood. I changed all 4 on mine.It might make it less difficult if you move a couple of things that are in the way. What side is it on driver or passenger side?
Ok here goes. There are two bulbs for each side. When I turn my car on, the HEADLIGHTS are on the OUTSIDE of each pod. Start your car, look at which bulb is out. There is a rubber seal, or cup, that covers, about 4 inches round, each bulb. Pull the cover off. You will see 4 wires that attach as 2 wires each to the socket. Look closely and you will see a wire-type connector holding the socket onto the holder. It's spring fed, side to side, so take the spring off, remove the bulb socket, change the bulb, and reconnect in reverse. I think the drivers side is easier to change because it's not blocked by other things in the area. Let me know if you have other questions.
