Headlight burnt out! Urgh!
Old Jan 28, 2008 | 11:12 AM
Display_Name's Avatar
Default Re: Headlight burnt out! Urgh!
Post 4 keeps changing because it is hot-linked to AllData, not to a static image hosted somewhere that likes sharing with others.
My guess is that AllData doesn't like people using their webhosting to share images with non-subscribers.
Here's the linked-to URL, with a carriage return added at each / so you can see the structure of the linked-to location, clearly not an image file.
www.alldatadiy.com
/alldata
/AFI%7EV11032335%7EC41380%7ER0%7EOB0%7EP4R0H%7EN
/0
/108596970
/110704162
/110705900
/110705902
/34853741
/34867926
/34869191
/114143136
/118361445
/118361446
Old Jan 29, 2008 | 03:40 AM
all_Bran's Avatar
Thanks for the help guys. Worked like a charm. Definitely different from my Neon install, so I'm glad I asked the How-To question.
I got a great deal at Murray's on the SilverStar Ultra Bright (one step above SilverStars). $32 for the H7 pair!!! They're bright as heck and were easy to install. Thanks again guys!! You saved me $50!
ps - I'm assuming the wiring can handle higher output bulbs, right?
Old Jan 29, 2008 | 03:49 AM
robby363's Avatar
Glad to hear everything worked out ok. They can be a pain in the *** to change. The wattage is still the same as oem they're just whiter and brighter so everything will be ok.
Old Jan 29, 2008 | 01:58 PM
all_Bran's Avatar
They're definitely brighter!! Very noticable. Worth the investment if you do a lot of night driving... Definitely worth the $32 they're on sale for at Murrays (normally $53).
Old Jan 29, 2008 | 04:10 PM
strupgolf's Avatar
Well, glad you got it figured out, not bad I hope. What is Murrays? Is that like Autozone etc.?
Old Jan 29, 2008 | 04:26 PM
cgocifer's Avatar
HIDs are not stock on the Xfire, but I added my own. They look factory and have worked very nicely. The headlights were a pain to remove, but still only took about 5 minutes on each side to remove the old standard filament bulb and replace with the HID bulbs. Should have been factory!!
Old Jan 29, 2008 | 05:58 PM
all_Bran's Avatar
Sorry, I wans't sure how nation wide Murrays is. Yeah, it's an Autozone, Pep Boys, Advance Auto Parts, etc...
smfrycruzr
Jul 17, 2023 05:33 PM
srtmodder
Aug 23, 2017 08:28 PM
Franc Rauscher
May 9, 2016 12:04 PM
tritongreen
Sep 18, 2015 07:32 AM
RacerXofFL
Sep 15, 2015 05:00 PM
