Oil Filter question
Old Mar 26, 2008 | 05:15 PM
kurtisberry's Avatar
Default Oil Filter question
Had my Xfire serviced at the dealer today. Just the normal stuff, state inspection, head light replacement, seat heater replacement, LOF.
They put in an AC-DELCO PF2247G cellulose oil filter for $17.77.
I bought the real fleece filter for $18 from an MB parts site.
My question is, can I replace the oil filter without draining the oil?
Looks like the filter is at about the highest point on the engine, so I think so, but would like some input before I make a mess of my driveway.
I have a top-sider just in case.
Kurt
Old Mar 26, 2008 | 06:54 PM
Chris2806126's Avatar
Default Re: Oil Filter question
Shouldn't be a problem. It's right there on top up front. Chances are you won't even have to top of the oil. All the oil that is soaked into the paper filter would probablly add up to a couple of ounces.
Old Mar 27, 2008 | 09:18 AM
maxcichon's Avatar
Kurt
Slightly loosen the filter cap enough to break the suction (clear the o-ring) and wait 5 minutes to let ALL the oil drain out of the cap volume.
Old Mar 27, 2008 | 02:02 PM
It's no problem.
I changed mine to a fleece between oil changes.
When the engine is cold from overnight I changed mine with no mess at all.
Old Mar 28, 2008 | 03:21 AM
ws6vert's Avatar
.....no mess no problem.....easiest filter chnage I've ever done..
Old Mar 28, 2008 | 03:35 AM
apkano's Avatar
Life is random...so am I.
Great advice.
I actually crack the seal after I've pulled the plug out of the pan for a complete oil change.......then I let it sit and drain overnight.
deerhunter
Jan 16, 2021 10:56 AM
PNA
Nov 12, 2020 04:44 PM
xfireohio
Jul 20, 2020 12:03 AM
sittininthesun
Aug 24, 2015 10:47 AM
steps
Jul 27, 2015 03:14 PM
