Greetings and Questions
Old Apr 16, 2008 | 06:28 PM
FTroopChief's Avatar
Post Greetings and Questions
Hello all Y'all from a new owner. Thanks for having such an informative site, I'm finding answers to many of my questions and many I haven't thought of. I find the comments about tires, tire wear, and the comfort zone of interesting. I am sometime and miles away from replacing mine, however the recent post about the Goodyear F1 to be of particular interest. I will be looking for follow-up on the treadwear and comfort zone. I would also like to see the causes of premature tire wear that has been complained about, and if it is the tire or the driving habits? Comments about what the optimum tire pressures are. I know what the book says, and I know the maximum pressure recommended by the tire manufacturer. I found all tires on my '05 Limited Coupe between 50-52psi. I know the variables vs mileage etc but with road temperatures reaching 120-130 degrees in the summer, how dangerous is this? Thanks and see ya on the road.
Old Apr 16, 2008 | 06:49 PM
Mike-in-Orange's Avatar
Default Re: Greetings and Questions
Was that pressure range of 50-52psi hot or cold? Cold they should be 32psi or so (can't recall the exact numbers off the top of my head) and I seriously doubt they'd gain 20psi under normal driving conditions. You'll end up with premature wear down the center of the tires at those pressures, handling will be compromised, the ride will be harsh but the fuel economy will improve. Check the driver's door jamb for proper cold inflation pressures and set all tires per that label when cold.
Old Apr 16, 2008 | 07:05 PM
Rapps's Avatar
HI welcome aboard it's a friendly place, good people, loads of info, hope you enjoy the forum/meets/GTG Rapp's
Old Apr 17, 2008 | 02:02 AM
crossfirefun's Avatar
Welcome to the forum. When I got my 04 I couldn't understand why the ride was so jaring, I checked the tire pressure and found they were over 42. When I dropped them down to 34 it drove much better.
Old Apr 17, 2008 | 07:09 AM
xfire2005's Avatar
Congratulations and welcome to our forum!
Old Apr 17, 2008 | 07:50 AM
WELCOME!
It is very beneficial to take the time to read the Owners Manual a couple of times. There is a lot too these machines.
Old Apr 17, 2008 | 08:14 AM
Stogey's Avatar
Welcome to the forum !
I run 35psi cold pressure in my Conti's, very comfortable ride and I'm seein no weird wear patterns.
Just my Dos Centavos !
Old Apr 17, 2008 | 11:15 AM
chuck65's Avatar
Welcome to the forum. There's a big difference between maximum pressure and recommended pressure. 50-52 lbs. is way too much. Check the sticker on your drivers door jam for the reccomended pressure. At 50-52 lbs. it would ride so rough you might chip a couple of teeth.
TerryR
Dec 13, 2019 03:27 PM
jimf
Oct 10, 2015 10:22 AM
2005 Ragtop
Oct 3, 2015 03:01 PM
Charlesl
Sep 30, 2015 10:46 PM
brandoni
Sep 30, 2015 07:48 PM
