short throw shifters
Old May 26, 2008 | 07:46 PM
badseed1's Avatar
Default short throw shifters
Hey, are there any short throw shifters that i can purchase for my 2007 XF?
Links, pics, install info, prices much appreciated, thanks!
Old May 27, 2008 | 03:13 PM
badseed1's Avatar
Default Re: short throw shifters
Cmon guys I know someone here knows something about short throws!
Old May 27, 2008 | 04:48 PM
Hangman's Avatar
The shifter throw on the XF is not short enough???
Old May 27, 2008 | 04:51 PM
badseed1's Avatar
I wouldn't mind a shorter throw.
Old May 27, 2008 | 05:03 PM
Maxwell's Avatar
the sport c320 has the short throw shifter, and so does the crossfire, but I think renntec made a custom shifter a long time ago.
If you want a shorter throw you need a new ****, this way you can lower the hight.
Old May 27, 2008 | 07:03 PM
TVT_DESIGN
Guest
Posts: n/a
We offer a Lower Lighter MOMO CF/Leather ****. It makes the shift less effortless.
Check it out: http://www.tvtdesign.com/inc/sdetail/375
To my knowledge there are no short shift kits like in a Mustang.
Old May 28, 2008 | 06:48 AM
ZAHANMA's Avatar
i personally think the throws are short enough... the only thing that could be better is a smoother shift.
Old May 28, 2008 | 07:15 AM
spensley's Avatar
Take the current shifter out, cut out the desired amount and then weld it (stiffeners if necessary, or an outer tube) it wil all be hidden by the boot (unless you have an auto tranny).
Old May 28, 2008 | 07:16 AM
blackberry's Avatar
Six spped is a new breed for me. Took a while to figure that it always wants to go to center which is 3rd and 4th. 2nd gear is an uncomfortable pull for me, seems to be into my hip instead of straight back. Oh well, just an old 4 speed guy that is having a blast with his Crossfire.
Old May 28, 2008 | 07:32 AM
apleschu's Avatar
I agree, the throw is short enough. And as far as smoothness goes: It gets better over time. If this is the same as all the other MB gearboxes (and I have no reason to believe otherwise) the gearbox gets better and better until you are at about 30k miles. I have 7000 now on our Xfire in the last two months and it is already remarkably better than on day one.
Old May 28, 2008 | 07:41 AM
hoverhog's Avatar
I too think the throw is pretty good i would like a more precise shifter the stock shifter is very spongy not a good shifter when it comes to quick shifts.I here what you are saying about the 2nd gear i keep ending up in 4th instead of 2nd
Old May 28, 2008 | 07:49 AM
badseed1's Avatar
When you say that, do you mean that there is no way to make the shifts smoother and less clunky, and no way to put a sort of "stopper" at the end of the shift?
I like to shift a little hard, and it always worries me what would happen if i pushed the shifter into the gate too hard, because older and more experienced drivers have told me that it isn't good.
Old May 28, 2008 | 08:21 AM
sonoronos's Avatar
Well, the shifter is a little different than the shifter you'd find connected to a Tremec.
On a Tremec like you find on a mustang, the lever is actually attached to the transmission. The XF has a parallelogram linkage that pushes and pulls on the main shift rod. Then there is a selector cable that's activated when you go left to right, along with a reverse lockout box.
The selector is very short throw (the left/right motion on the shifter between 1-2, 3-4, and 5-6) but you are right, there is room for work on getting the shifter to move a shorter distance front to back.
The solution unfortunately isn't a "stopper", as the shift distance is necessary to move the synchros from one gear to another. Stopping the shift "short" would cause grinding or incomplete engagement.
What's necessary is to basically increase the lever arm between the shifter and the main shift rod/fork. It's possible. Maybe some enterprising fellow can engineer one.
Old May 28, 2008 | 10:23 AM
brianm929's Avatar
Like a fine wine it does get better with time. I too am finding the shifting to improve with time. I have 15000 on mine.
Old May 29, 2008 | 06:03 AM
ZAHANMA's Avatar
ill take you and apleschu on your words. i picked mine up only two months ago (4/5) and just passed 4k the other day... hopefully in the next 5k i will see this improvement you speak of...
Old May 30, 2008 | 02:19 PM
badseed1's Avatar
that's what I was afraid of...
Just for clarification, it is bad to push the shifter too far forward into the gate, right?
Old Jun 30, 2008 | 10:22 PM
newCrossfire's Avatar
do you think possibly a shorter heavier **** would give the feel were all lookin for? i have no experience in this but think it could work somwhat.
Old Jul 1, 2008 | 05:54 AM
ZAHANMA's Avatar
the actual shifter **** for the manual transmission is a specially designed for the car because of the reverse proceudre...not easily duplicated.
Old Jul 1, 2008 | 04:15 PM
Goldwing's Avatar
I'm at 28k and have not seen much difference in "smoothness". I think that after I get used to driving it again each spring, I just shift a little better. But I am hoping over the next 10k it smoothes out a little and is not a notchy between 1st and 2nd.
PS - I usually shift 4th to 6th as 5th doesn't do much for me. That's a "long" shift.
Old Jul 1, 2008 | 04:43 PM
TVT_DESIGN
Guest
Posts: n/a
The **** really has nothing to do with that. You can fit any **** on these cars that you want. The MOMO ones we offer are not made to fit this car, but we modify them so that they do.
**** design is more important in an auto then a manual.
