ripples in door arm rest
Old Sep 1, 2008 | 07:46 AM
kjnc's Avatar
Question ripples in door arm rest
Has anybody found their drivers door armrest forming several ripples in it where ones elbow rests? Is there a way to remedy that without replacing the whole door panel?
How do you remove the engine cover to access the air filter?
kjnc
Old Sep 1, 2008 | 08:06 AM
+fireamx's Avatar
Default Re: ripples in door arm rest
kjnc
The only thing that I've noticed is a slight "depression" where my "boney" elbow rests.
My suggestion would be to take a electric hair drier and warm up the area and see if that softens the material enough to work out the ripples.
I believe all you need to do is pull up the engine cover from the rear. It's only held in place by rubber grommets.
Old Sep 2, 2008 | 10:13 AM
Goldwing's Avatar
Gently tug the cover straight up starting in the front and then working to the rear. There are 1-2 grommets under the front, but definitely two in the rear, one in each corner.
Old Sep 2, 2008 | 12:47 PM
+fireamx's Avatar
According to the 2004 Service Manual Volume 2, page 9-608
Under Engine Service Information
Air Cleaner Housing
Removal
Note: The air cleaner is held in place by two rubber grommets and two spring clips.
1. Remove the air inlet tubes (2)
2. Lift the air cleaner housing from the rear first, then from the front and remove it.
Osusannah
Feb 12, 2024 01:49 PM
Valk
Jul 12, 2021 09:49 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
Oct 1, 2015 01:42 AM
Billy22Bob
Sep 28, 2015 08:08 PM
