Clutch Adjustment, Second gear downshift
Old Sep 30, 2008 | 07:49 PM
kloller's Avatar
Default Clutch Adjustment, Second gear downshift
I recently had the clutch replaced under warranty after it failed suddenly. Seems now that the clutch does not engage until the pedal is a couple of inches off of the floor. Can this be adjusted easily? I have not put the car on ramps yet. What should the clutch pedal travel be before the clutch engages ?
I am also having problems getting the car back into second gear on downshifts some times. Is this a shifter adjustment issue ? Before the clutch failed the shifting seemed to be real smooth.
Old Oct 1, 2008 | 03:20 PM
Shawnkey's Avatar
Default Re: Clutch Adjustment, Second gear downshift
Sounds like a fluid issue. Take it back, because it's a modular, self-adjusting clutch. Maybee just air in the line, or a possible slave cylinder issue.
jimf
19
Oct 19, 2015 04:05 PM
jimf
Oct 10, 2015 10:22 AM
2005 Ragtop
Oct 3, 2015 03:01 PM
rfourt
Sep 25, 2015 01:38 PM
atdavis2
Sep 21, 2015 01:25 PM
