Pics of the new Engine Bay
on
What do you all think, keep in mind that this utilizes the stock forced or ram air through the filters and let me tell you I like the sound and the improved preformance.
on
1 Post
on
Re: Pics of the new Engine Bay
Attachment 11730Attachment 11731
Attachment 11732Attachment 11733
Is there a noticable difference now that you have some "cold" air to play with? Or is it just suction sound?
on
Originally Posted by FP
Very nice setup. Where did you find the tubes to go out through the front?
I used my stock tubes but had to cut them down and use a rubber hose coupling, the tubes from the air box to the filter. I bought from a local parts store they are 6'' tubes with a 22 degree bend and the filters are spectre. They only had the white filter but spectre does make a red one so in the future they will be red to match the car.
And yes the sound is much deeper and it seems like the acceleration is alot easier. Overall for the $90 I spent I am very pleased with the results
on
It looks s very nice under the hood. But I am not sure how you getting the cold air thru the filter? I see the hoses that are forward of the filter, but the filter element is still exposed to hot eng compartment. Please explain.
Thanks, James
Thanks, James
gotta give you a warning, i assume you used the ebay style filters with the inverted cone on the face, they have a quarter sized peice of metal in the center of them right? if so they are prone to being sucked into the airstream. some srt-4 owners have whiped out turbos due to this
the hot air is going to get you on this setup, your trading slightly less restriction for undoubtably hotter air.
if you want to keep this style of intake id recommend you to switch to a k&n or other quality brand filter
please dont take offense to my comments but i guess id rather you be slight ticked about it then having to replace a motor due to the metal disc getting caught in a valve
Good to know. I traded up to K&Ns before installing my cone filters.
Thanks...
on
let me dig up a picture of what im referring to...
http://www.bonesenterprises.com/pics/icn11058.jpg
ok, see the round metal quarter sized disk on the center of the face of the filter. yours doesnt have that right?
BrenLW
08-05-2015 04:53 AM
07-24-2015 07:57 PM
axnguyen
07-21-2015 11:41 AM
