ABS Control Module
Old Oct 21, 2008 | 08:25 AM
Steenport567's Avatar
Default ABS Control Module
How do I replace the ABS control module? Anyone know if I can do this at home?
Old Oct 21, 2008 | 09:11 AM
robby363's Avatar
Default Re: ABS Control Module
That's something you might want to leave for a pro. If it's where I think it is on the hydraulic control unit you have to disconnect all the hydraulic lines to get to it. Why do you think there is something wrong with it.? If the ABS light is on it could be one of several different sensors that could be the problem. Your better off having a tech diagnose the problem.
Old Oct 21, 2008 | 09:21 AM
I did that and the dealer said it WAS the module.
Old Oct 21, 2008 | 09:24 AM
robby363's Avatar
Did they say where it's located?
Old Oct 21, 2008 | 09:25 AM
Goldwing's Avatar
I can't help you with the removal, but when I had the ABS fail on my A6 I found a place out west that rebuilt them for about $250 vs over a grand for a new OEM. Not sure if they do Crossfires, but if this is a Mercedes part they may. Worth looking into depending on parts cost. Do a google search.
The ABS on the Audi does not pump any brake fluid. It is the "brain" that hooks to the master cylinder and that takes care of the balancing (as I understand it). I was able to drive the Audi for a couple weeks w/o the ABS module. It braked fine under normal conditions, no need for ABS.
Old Oct 21, 2008 | 09:50 AM
robby363's Avatar
This should help you if it's the control module they said is the problem.
Old Nov 13, 2008 | 05:48 AM
themarine82's Avatar
Hey I have a ABS control module for sale! P# 05161125AB
Ryan
the_marine82@hotmail.com
syfi
Mar 28, 2026 04:14 PM
johnnycross413
Mar 4, 2016 04:49 AM
2005 Ragtop
Oct 3, 2015 03:01 PM
Oct 1, 2015 01:42 AM
Billy22Bob
Sep 26, 2015 10:16 PM
