Chrysler Coupe Security
Old Dec 24, 2008 | 06:57 PM
tayabchinyoty's Avatar
Default Chrysler Coupe Security
Guys,
I am putting an automatic starter inside my crossfire.
the guy needs information about factory alarm, where is it and what are the wire colour codes.
Please let me know if there is somewhere where i can see or someone who can help me.
thanks
white crossfire 03
20" and 22 "
Old Dec 24, 2008 | 07:08 PM
70GT6's Avatar
Default Re: Chrysler Coupe Security
Old Dec 24, 2008 | 08:08 PM
faiz23's Avatar
i don't have the info you are needing but i have worked on car installing remote starts and alarms along with keyless. the crossfire is a tricky car with needing to split the door lock triggers and diode isolating both.
in remote start he will need to know the bypass info and you have to give up a key.
if your installer does not know where to get the info for wiring or directechs he is not qualified to install the setup. needing to know how to splice into the starter or bypass the factory system using a transponder bypass. please find a shop that has a lifetime warranty.
i got a viper 5901 installed in my manual transmission but i am still working out all the minor bugs to fix it is not a everyday car to work on definitely need plenty of time
Originally Posted by tayabchinyoty
Guys,
thanks
white crossfire 03
20" and 22 "
Old Dec 26, 2008 | 08:51 AM
Goldwing's Avatar
A 2003 Crossfire. You got one of the real early ones.
Old Dec 26, 2008 | 08:17 PM
07bluezx14's Avatar
While having my audio system installed, one of the guys commented that getting around all of our pre existing security is a pain. I would expect that it will take a while to install, a remote start equaling $$$$. I would like to have one on mine though. good luck, chris
Old Dec 26, 2008 | 10:37 PM
nox1s's Avatar
Guys,
thanks
white crossfire 03
20" and 22 "
find a new shop, honestly.
the crossfire security isn't something to be taken lightly. with the transponder, you're going to have to glue the chip to either the ignition (or somewhere real close) or to the actual key.., plus if he can't find out where to tap into what wires / etc, then that's not a very good shop.. that's what they are paid for and what they are suppposed to know.
Old Jan 6, 2009 | 09:38 PM
Hey ppl, not any help by anyone in this forum but this is what i compiled when we did my car.
its a crossfire 2003
Battery Constant 12v+ Positive Wire (+): Red
Battery Constant 12v+ Positive Wire Location: Ignition Switch Harness
Starter Positive Wire (+): Purple
Starter Positive Wire Location: Ignition Switch Harness
Ignition Positive Wire (+): Pink/Red
Ignition Positive Wire Location: Ignition Switch Harness
Second Ignition Positive Wire (+): Pink/Yellow
Second Ignition Positive Wire Location: Ignition Switch Harness
Accessory Positive Wire (+): Pink/Dark Green
Accessory Positive Wire Location: Ignition Switch Harness
Parking Light Positive Wire (+): Gray/Black and Gray/Red (Use Both). The parking lights on this vehicle use a 2-wire system and will require an extra relay part.
Parking Light Positive Wire Location: At Illumination Control Module. The illumination control module is part of the headlight switch.
Power Door Lock Negative Wire (-): Blue
Power Door Lock Negative Wire Location: In Drivers Kick Panel, Door Harness
Power Door Unlock Negative Wire (-): Black
Power Door Unlock Negative Wire Location: In Drivers Kick Panel, Door Harness
Door Trigger Negative Wire (-): Brown/Gray and Brown/Pink (Use Both). This vehicle has 2 door trigger wires, when connecting to an alarm system use both wires and diode isolate.
Door Trigger Negative Wire Location: At Security System Module. The security system module is located is on the right rear floor of the luggage compartment.
Domelight Supervision Wire: Brown/Gray (Requires Relay)
Domelight Supervision Wire Location: At Security System Module. The security system module is located is on the right rear floor of the luggage compartment.
Horn Negative Positive Wire (+): Black/Pink
Horn Negative Positive Wire Location: At Horns or at the Relay Control Module. The relay control module is located in the control module box next to the battery under the hood.
Tachometer Wire Negative Wire (-): The tach wire is located at the ignition coil use a wire that is not black/dark green or black/yellow.
Tachometer Wire Negative Wire Location: At Ignition Coil
Brake Light Positive Wire (+): Black/Red
Brake Light Positive Wire Location: At Relay Control Module. The relay control module is located in the control module box next to the battery under the hood.
Factory Alarm Disarm Wire (-): Disarms With Unlock
Factory Alarm Disarm Wire Location: N/A
Old Jan 7, 2009 | 07:44 AM
I know this is not the topic here but I never heard of a 2003 Crossfire ??
Build date 03 maybe but title and registration 2003 ??
Are you positive??
I just posted yours in the featured daily pic thread as a 2004
Old Jan 7, 2009 | 12:23 PM
Iamfink2's Avatar
Are you positive??
Gary I believe North America is one of the only places that designates model years alot of other countries base the model year when they are manufactured.
Old Jan 7, 2009 | 01:16 PM
patpur's Avatar
Senior Member/Moderator
First one I saw was on June 28th 2003 at Marlow Heights, Md DAR Cars Chrysler when I bought my 03 GT Cruiser. I'm sure that one had an 03 build and it was summer of 03, they may have considered it an 04 but what I do remember was it was beautiful (I fell in love) and there was a big orange sign in the window that said $37,500 FIRM. That made me say "another day".
Pat
Trenzman
Jul 24, 2015 10:12 PM
ChrissyCrossfire
Jul 22, 2015 03:26 AM
TomSRT
Jul 21, 2015 06:50 PM
Dave Wilson
Jul 18, 2015 05:31 PM
bbsrt6
Jul 12, 2015 09:35 PM
