Horn Volume!
Old Feb 19, 2009 | 12:35 PM
Bob Ride's Avatar
Default Horn Volume!
Hi everyone, I'm not a constant horn blowing type driver, but in 8 months of owning my '05 coupe I've noticed that my horn volume is kinda low and actually sounds lame compared to stock factory horns on my other vehicles. Not having other Crossfires around to compare with, I wonder if this is normal ? or is mine defective?..Any advice would be welcomed..Thanks
Old Feb 19, 2009 | 12:38 PM
danimal's Avatar
Default Re: Horn Volume!
I think it is the norm. I replaced mine with Hella horns. There have been some reports on either one or the other horn not working so you may want to check them and wiring to see if that is the problem.
Old Feb 19, 2009 | 12:47 PM
Bob Ride's Avatar
Thanks for the info. You also answered my next question which was what brand of horns would be a good replacement. Thanks again.
Old Feb 19, 2009 | 01:42 PM
Goldwing's Avatar
Were the Hellas a direct fit? Part number and price would be helpful. A direct replacement with a louder horn is attractive.
I've been eyeballing some inexpensive air horns (< $40) which I used to have on a TR6 years ago, but have held off because I did not want to change from stock. I may look at just adding them in under the hood and wiring them in parallel with the existing horn.
Old Feb 19, 2009 | 03:17 PM
BORICAN's Avatar
I installed Air Horns on mine and they work great. They are pretty loud too.
Old Feb 19, 2009 | 03:45 PM
RickZ's Avatar
Check the connections on your horns, one of mine wasn't making a good connection where it plugs in and with only one working it sounds like it belongs to a Fiat or VW Beetle...
Old Feb 19, 2009 | 05:03 PM
danimal's Avatar
They are a direct replacement....couldn't be easier.
http://www.griotsgarage.com/product/...hella+horns.do
Old Feb 19, 2009 | 06:17 PM
H82BL8's Avatar
I'm putting in new horns right now. Check "technical or modification section" - Stebel Nautilus Compact horns. I'll post some pictures in the next few days.
Old Mar 7, 2016 | 10:12 PM
Fildo Dog's Avatar
Borican:
How did you wire them? Are the horns positive switched or negative? The diagram would suggest negative switched. Installing nautilus air horn on half with relay and fuse. Want to verify switching polarity. Thought your experience might help me.
Fildo Dog
Old Mar 7, 2016 | 10:46 PM
JEFASOLD's Avatar
Originally Posted by Fildo Dog
Borican:
Fildo Dog
That thread is over 7 years old and I haven't seen that member on here since I joined in 2012 but I'm sure if you search you can find another relevant thread. I do agree, the horns aren't loud, I just purchased 2 from Sickspeed rated at 118 db.
RED DOG
May 4, 2019 08:05 AM
Selbyl
Sep 22, 2015 10:41 PM
LE Cross
Sep 14, 2015 01:20 PM
81's
Sep 13, 2015 04:34 PM
pioneer4x4
Jul 27, 2015 02:04 PM
