Electrical problems with fuse blowing
Old Feb 25, 2009 | 06:16 AM
blackcrossfire07's Avatar
Default Electrical problems with fuse blowing
Quick recap... my dealer took my center console apart to fix an AC problem. I used a damp cloth to wipe down the center console panels (maybe it got a little too wet). I go to use my side mirrors and it moves for a second and stops. The fuse is blown. The car sat in the sun all day in 80 degree temps. I replace the fuse and it blows again after a second of the mirror moving. Do you think it may still be damp in there? Or do you think it is more of a wire issue cause by the dealership?
Old Feb 25, 2009 | 06:30 AM
Stogey's Avatar
Default Re: Electrical problems with fuse blowing
My gut feeling tells me that the dealer may have pinched a wire putting the dash console back together !
Old Feb 25, 2009 | 06:45 AM
It is very possible. I am getting tired of bringing it in. This will be #4 (which includes bringing it in the first time for the original problem).
Old Feb 25, 2009 | 06:52 AM
I almost want to check this out and fix it myself. Any tips? Anybody know how the wires run? I need the radio key to get back there.
Old Feb 25, 2009 | 07:58 AM
rekcah's Avatar
attached pdf
File Type: pdf
Old Feb 25, 2009 | 09:13 AM
Can you manually push the mirror to adjust it?
Old Feb 25, 2009 | 09:34 AM
rekcah's Avatar
I've manually moved it when I was cleaning them. Don't know if it does anything bad to the motor though.
Old Feb 25, 2009 | 02:17 PM
I tried to move the mirror with my hand and it won't stay in the place that I set it. I may not be using the force that I need to... but I don't want to break it. I just put a few more fuses in and each one broke instantly. Definitely a problem with the wire. A short maybe....
Old Feb 25, 2009 | 02:20 PM
waldig's Avatar
Talking Re: Electrical problems with fuse blowing
Do they blow without trying to move the mirror, ie an immediate short failure? If so get an ohm meter and connect it and start trying to follow the wires/ cable.
BTW water wont blow fuses in a 12 v circuit, it will lead to rapid corrosion but can not conduct but a few milliamperes.
Woody
Old Feb 25, 2009 | 02:29 PM
It is an immediate short.
Old Feb 25, 2009 | 02:57 PM
GDC-SRT's Avatar
I think this is a real good answer
xfClifford
Mar 3, 2021 04:52 PM
northwest_crossfire
May 30, 2016 05:19 PM
x1xsinisterx1x
Aug 24, 2015 07:31 PM
Helot
Aug 15, 2015 04:19 PM
BrenLW
Aug 5, 2015 04:53 AM
