Strange Noise...Help! :-)
Old Jul 24, 2009 | 05:57 AM
Style's Avatar
Unhappy Strange Noise...Help! :-)
Hi all...this is pretty vague I know but does anyone have any suggestions on this:
What is the noise:
  • Car idles at normal revs fine
  • Put transmission in neutral and depress brake peddle at normal idle no problems no noise.
  • Put transmission in drive depressing brake pedal (i.e. car is stationary) at normal idle speed = a low rumbling noise.
It is obvious that it comes from the transmission area as it only happens when drive is engaged and the brake pedal is fully depressed. (haven't heard it under toque on the open road...wind/exhaust to loud to hear the low rumbling even if it is apparent at that time)
It's not significantly loud, nor does it sound like a loose or worn transmission mount. Has anyone experience anything similar?
Old Jul 24, 2009 | 06:19 AM
crossfirefun's Avatar
Default Re: Strange Noise...Help! :-)
In gear under load puts pressure on the engine,trans, and exhaust. I would check out the clearance on or around the exhaust and hangers first. It might be just close enough under load to be rubbing on something.
Old Jul 24, 2009 | 08:07 AM
Style's Avatar
mmm, thanks for that I'll check that out but from inside the car if feels a more "internal" sound, like within the transmission.
If anyone has had a Lexus SC400 you'd know that the nitrogen canister for the ABS looses pressure over time. The sound of the compressor running to keep the pressure up in the canister is not unlike this sound.
Keep the suggestions coming please
Billto
16
Sep 1, 2016 11:06 PM
steps
Sep 19, 2015 10:43 PM
xjken
Sep 13, 2015 10:18 PM
Abaton6
Aug 16, 2015 12:55 PM
arkady
Jan 16, 2008 06:12 AM
