Headlight Problem
Old Aug 13, 2009 | 01:05 AM
Phil423's Avatar
Default Headlight Problem
I just registered on here. i've had my crossfire for about 5 months and the headlights seem to point about ten yards out and then don't shine much farther. i've replaced the bulbs and adjusted the **** all the way up and it still doesn't help much. in good conditions its a manageable problem but if it rains in can't see anything. is there a way to point the projectors up higher or is this a permanent problem. i'm thinking about getting a HID kit, would this give my lights more distance. any advice will help. thanks
Old Aug 13, 2009 | 08:20 AM
maxcichon's Avatar
Default Re: Headlight Problem
The problem you are seeing(!) is the bulb is not properly seated in its little detent. They can be a bear to get right. Release the clip and try to rotate the bulb while it is on. Take a look first to see that the tab is even close to being in the right place-use a small mirror if you must.
HID's are great for these cars. Check out the "Sticky" in the Lighting forum.
Oh-you will need to re-adjust the screw when you finally have it right.
Old Aug 13, 2009 | 08:29 AM
Max is the expert here, so read thru the threads, and if you go HID's, Max is the man....to help you out...welcome to our forum....you will learn everything you need to know about your new little car here...
Old Aug 13, 2009 | 09:52 AM
Phil423's Avatar
Thanks all try readjusting the bulb right now.
Old Aug 13, 2009 | 11:16 AM
Stogey's Avatar
Welcome to the Forum ! Enjoy the ride !
Old Aug 13, 2009 | 11:28 AM
Phil423's Avatar
ok so all i had to do was rotate the bulb 90 degrees and now its perfect. the person that had the car before me put them in wrong and messed me all up. now they fit perfect and make a world of difference. Thanks
Old Aug 13, 2009 | 12:15 PM
I think you will find that most of your questions will be answered that quickly here.
This has been the case for me, I'v been here just over a month.
Old Aug 13, 2009 | 01:30 PM
maxcichon's Avatar
Great!
now you know how to replace them with HID's!
HID kit xenon conversion H1 H3 H4 H7 H11 9005 9007 9006:eBay Motors (item 390080283234 end time Aug-13-09 07:21:39 PDT)
Old Aug 13, 2009 | 11:20 PM
Phil423's Avatar
yes i just bought a HID kit today off Ebay (you got to love that place) and can't wait to put them in.
gp1200x
Dec 6, 2015 12:59 PM
gp1200x
Nov 24, 2015 04:39 PM
pioneer4x4
Sep 24, 2015 11:17 AM
ChrisA
Aug 17, 2015 09:54 PM
mike28117
Aug 16, 2015 10:32 AM
