How does one get the crossfire rear on jackstands?
Old Sep 15, 2009 | 03:05 PM
ninsei's Avatar
Default How does one get the crossfire rear on jackstands?
Hi. on my mom's 2004 crossfire (yes my mom has this car), i gotta change out the rear pads and I like to use jackstands.
Old Sep 15, 2009 | 03:07 PM
former NXMX5's Avatar
Default Re: How does one get the crossfire rear on jackstands?
There is a jack point right in front of each rear wheel. jack the car up by the differential, place jack stand.
Old Sep 15, 2009 | 03:28 PM
LugNut's Avatar
Question Re: How does one get the crossfire rear on jackstands?
How 'bout for putting the frontend on jackstands? The FSM says not to use the lower control arms to jack up the car, and the center crossmember, behind the plastic pan, looks too flimsy for a floor jack.
Old Sep 16, 2009 | 12:19 AM
newCrossfire's Avatar
there are two jack points on each side of the car just below the rockers.
Old Sep 16, 2009 | 12:39 AM
tighed1's Avatar
That makes four total ninsei.
Just take a look along the sides of the car behind the front tires and in front of the rear tires.
BE SAFE!
Old Sep 16, 2009 | 07:06 AM
LugNut's Avatar
"there are two jack points on each side of the car just below the rockers."
Yes, but they either can be used for the floor jack, or the jack stand, not both at the same time. So need other lifting points if the jack stands are to go under those plastic "hard points".
Old Sep 16, 2009 | 08:42 AM
here you go...
Old Sep 16, 2009 | 09:14 AM
patpur's Avatar
Senior Member/Moderator
I was thinking exactly what Lug Nut was thinking. You can't use the jack points for the jack and the jack stand at the same time. I've jacked up the rear at the differential very gingerly. The front I set the jackstand right next to my floor jack and set it just in case the floor jack does collapse the jack stand will catch the car. My jackstand also has a pin in it that would catch it if it fails.
But the question still remains............?
Old Sep 16, 2009 | 02:24 PM
LugNut's Avatar
here you go...
Except ... my add-on question was about the front end.
I didn't look when I dropped the plastic aero pan under the front (when I did my only oil change so far), but maybe there's a strong K-member under there. Would be a pain to drop the pan every time I want to pull a front tire. (I also want to pull all the wheels at one time to clean their back sides, and to paint all the wheel wells flat black).
Old Sep 17, 2009 | 09:18 AM
i jack the car up by the front jack point (i have two jacks so it an "even" lift), and put a horse underneath the control arm, where the two 'arms' meet the spindle.
Old May 5, 2011 | 09:26 PM
silverfish1's Avatar
Banned
Angry Re: How does one get the crossfire rear on jackstands?
Again the guy is asking a simple question and i will agree with him, Are the lifting points that you jack the car up with Ok to also use jack stands?
Dont fake the funk on this one
Old May 5, 2011 | 10:07 PM
MikeR's Avatar
There is a beam towards the center of the car in line with the front jack points...that has a diagonal stiffening brace attached... I put my front jack stands at that point.... works good and is solid....
Old May 6, 2011 | 07:46 AM
West Peterson's Avatar
If I remember correctly from when I changed out my wheels and installed driving lights, if you jack the rear high enough, using the point in front of the rear wheel, the front end will also lift off the ground.
Old May 6, 2011 | 10:17 AM
you guys are so funny....jack up either on the front and back jack point, and watch what happens>....
I have lifted the car high enough to place 3 jack stands under it from one jacking point, not recommended, but is possible...these little dudes are rigid. Recommended would be use the back jacking point to place the front jack stand. But if working only on the rear then, reverse this....good luck...I also place a small piece of wood between the car and the jack to protect the car...a piece of 2x4 will work...
Old May 6, 2011 | 02:25 PM
Airscape's Avatar
+1. When I swap my winter/summer sets I just jack it up using the front point until it is high enough to put a stand under the rear point.
Old May 6, 2011 | 02:50 PM
Pretty much what I said in post #13.
Old May 6, 2011 | 06:23 PM
I know we were posting at the same time....lol.....I concure....lol
rayth
41
Jul 31, 2019 04:02 PM
GraphiteGhost
Jun 15, 2017 12:07 PM
Crossfireconv08
Mar 31, 2016 05:29 PM
rmcdaniel12
Jun 10, 2015 03:51 PM
MJPowers
Jun 8, 2015 02:34 AM
