Self-locking doors
Old Oct 14, 2009 | 11:58 AM
blackcrossfire07's Avatar
Default Re: Self-locking doors
interesting. I will try these various options and see what happens. I will keep the 2nd key on me at all times, the other one will be tried in the ignition, and on the seat, and I'll see what happens. Perhaps when i did this on saturday it may have been one of those scenarios that I didn't put two and two together. Interesting, but bottom line is that I will make sure both keys are not in the car at the same time!!!!
Honestly, I don't trust any power lock system. I wouldn't leave the keys in it even knowing how the system works.
I am just telling you that I thought my car was self locking about a year ago. It drove me crazy until the dealer explained how everything worked. Sometimes you do things a certain way and don't remember (that was the case with me). I had no idea what I was doing... all I knew was that my door kept locking on me and I didn't know why. Now that I understand the system and how it works... everything is ok.
The car knows if you open the door! If the car is locked and you unlock it but don't open the door, it will relock itself. Remember that!
Old Apr 3, 2011 | 08:24 AM
eruby's Avatar
I did a search and could not find anything on what's happening. Sorry to raise an old thread but I've got a lock question. When i used to push the unlock button once on my 2005 LTD, it would only unlock the driver's door leaving the passenger door and trunk locked. I could push it again to unlock the passenger and trunk locks. For some reason it now unlocks everything with 1 push. I like the old way better. Is there a way to switch this back or did something just change with the car?
Old Apr 3, 2011 | 08:34 AM
eruby's Avatar
OK Sorry. I tried a few other seaches and found this:
Originally Posted by tighed1
BUMP!
Just wanted to bump this as some of the attendees at the CAA GTG weren't aware of this procedure.
Press and hold both buttons on the key remote until the light (red lens at top of key fob) blinks twice. Now when you press the open button both doors and trunk will open with one push instead of two!
Repeat procedure to go back to two presses to open passenger door and trunk (why??)
Old Apr 3, 2011 | 08:57 AM
6000rpm's Avatar
Yikes! I haven't had any problems with my '05 Coupe. Another fun thing to look forward to. (I hope not).
Old Apr 3, 2011 | 09:15 AM
smfrycruzr's Avatar
This is a feature on my PT Cruiser. Not sure if the Crossfire has anything like this, I tried scanning the owners manual, but couldn't find a simular reference. Might try a combination like this and see what happens, hope this helps.
Central Locking/Unlocking — If Equipped
All vehicle doors and liftgate are locked with the first
turn of the key to the LOCK position. The double unlock
activation feature requires you to turn the key in the
cylinder lock two times within five seconds to UNLOCK
all vehicle doors and liftgate at once. You may turn this
feature off and unlock all the doors and liftgate with one
turn of the key by following these instructions.
NOTE:
Steps 2 and 3 must be completed within 10
seconds.
1. Close all doors and place the key in the ignition
switch.
2. Cycle the ignition switch ON/OFF four times ending
in the OFF position.
3. Press the interior door lock switch to the UNLOCK
position.
4. A single chime will sound to signify that you have
successfully disabled the double activation feature.
You can turn the feature back on by repeating the above
mentioned
Old Apr 3, 2011 | 09:23 AM
smfrycruzr's Avatar
Figured as much, Tighed1 would know something like this. Went and programed both of my remotes to do this. Thanks for bringing up an old thread, learned something new about the Crossfire, again.
Osusannah
Feb 12, 2024 01:49 PM
Valk
Jul 12, 2021 09:49 PM
Mackel
Oct 16, 2015 09:03 AM
Billy22Bob
Sep 28, 2015 08:08 PM
jaesa
Sep 7, 2015 01:50 PM
