Any one done a Dyno test yet?
Has anyone done a Dyno test yet. I was thinking about taking mine in to see what kind of numbers I come up with before I start messing with anything. I've already changed the air filters to K&N. I'll put the stock filters back in for a run and then check it w/the K&Ns.
I read somewhere that without a STAR system, you can't go over a certain rpm (3k) on a dyno. It will sense the front wheels are not spinning and prevent you from getting your full range dyno pull. The STAR system however has a dyno mode you can disable that feature during the test.
The STAR system is the dealer hand held computer that connects to the communications controller on the car.
I had heard from a friend that Dyno tested his CLK that the stability/traction control can be disabled.... I'm not sure if it's pulling a fuse unplugging or what.... And that will take care of that problem. I'll get more info.
I tried to get a dyno test done a while back. Could not rev past 4K. We turned off the traction control but it didn't help. Tried applying brake load on the dyno- no joy. Something has to be turned off with the STAR system but I never pursued it any further.
johnnycross413
Mar 4, 2016 04:49 AM
