My light won't go off...please help
Originally Posted by floorthecrossfire
how do i check the oil level?
Turn the key to on/run but do not start... Wait until the beeps end... within a second or two of the beeps ending there will be an oil icon and a clock icon in the displays... while these are showing press the button twice within one second... your oil level will be displayed...
Thanks rhacker32
Thanks rhacker32
Thanks rhacker32
Thanks rhacker32
Now WHERE IN THE HELL IN THE MANUAL did you find that?
(Honestly, EVERY few days I learn something about this car...)
i checked the dipstick and it came up to the right spot. what should the dash say after i turn the car to run?
Here is the full procedure from the owners manual:
BC.
CHECKING ENGINE OIL LEVEL
A sensor in the oil pan allows oil level to be checked without opening the hood.
It provides an accurate measurement of oil level, whereas the low engine oil level indicator warns that oil level is definitely too low.
With the vehicle parked on a level surface, the engine is warmed up and shut off for approximately five minutes.
When the ignition switch is turned to the ON/RUN position, press the **** to the left of the speedometer once and wait seven seconds.
An ISO oil level icon appears in the trip odometer window and a “clock” icon in the cumulative odometer display.
Pressing the **** to the left of the speedometer twice within one second displays one of the following messages:
˛ OK
˛ -1.0 Q (-1.0L)
˛ -1.5 Q (-1.5L)
˛ -2.0 Q (-2.0L)
˛ HI
The indicated amount of oil must be added to the engine
if the message -2.0 Q (-2.0L) blinks and a signal sounds.
The HI message indicates that the excess oil must be removed from the pan to avoid possible engine or catalytic converter damage.
If the ISO oil level icon and “clock” icon remain on when attempting to check oil level and no message follows, or if the low engine oil level warning lamp comes on, a malfunction in the engine oil level system is indicated.
A conveniently located dipstick allows manual checking of the oil level.
If no leaks are noted, continue to drive to the nearest service station where the engine oil should be topped to the “full” mark on the dipstick with an approved oil.
˛ OK
˛ -1.0 Q (-1.0L)
˛ -1.5 Q (-1.5L)
˛ -2.0 Q (-2.0L)
˛ HI
xfClifford
27
Nov 10, 2015 10:08 PM
axnguyen
Jul 21, 2015 11:41 AM
KwehCat
Jul 16, 2015 04:48 PM
cx24724
Jul 12, 2015 11:57 AM
