I'm worried
Old Oct 22, 2009 | 06:23 PM
floorthecrossfire's Avatar
Exclamation I'm worried
well my crossfire i just bought has 53k on it and i stopped at a light today and once i stopped my car started to jerk like it was going to die then light turned green and i pressed gas and all was fine for a mile up then got gas. My gas tank light was on but was only halfway if that in the red it was only on maybe 5-10 miles. Should i be worried about my car bcause i thought the light means you have 2 gallons of fuel left. has this happened to anyone?
Old Oct 22, 2009 | 06:57 PM
tighed1's Avatar
Default Re: I'm worried
That just may be where you are out of gas. See if the problem continues now that you have put more gas in.
If it's a BLACK crossfire yer screwed!
Wouldn't be a bad idea to change the fuel filter since you don't know if its been done.
Report back.
Oh yeah. WELCOME to the forum!
Old Oct 22, 2009 | 07:01 PM
yeah the dealership i got it from didnt change oil, took it back and made them put mobil 1 in, they were very apologetic but dont thing\k they changed oil filter. Where can I have this done? should i get a tune up? i dont know when the last time it had one. I put shells VPOWER in it now made a mistake by using speedway the first fill up :-(
Old Oct 22, 2009 | 07:18 PM
hcarter's Avatar
Report back.
LOL
Old Oct 22, 2009 | 07:43 PM
Beaner's Avatar
Well just for your information when the gas light appears on my car I can drive 40.3 mi – about 46 mins with no signs of running out of gas on the highway
Old Oct 22, 2009 | 07:50 PM
MikeR's Avatar
About the same with mine Beaner....
OP... You may have just had some water or crud in the bottom of your tank too....
Old Oct 22, 2009 | 09:29 PM
The Beep's Avatar
If you're going to run it that low, pull the gas tank apart and clean it out first.
Old Oct 23, 2009 | 11:01 AM
I filled up with shell gas and it happened again today. Stopped at a light and it started to shake like it was going to die but didn't. I don't know what to do. Does anyone know what's wrong with it?
Old Oct 23, 2009 | 11:12 AM
tighed1's Avatar
Without knowing the car and with the little bit of info we have I would suggest checking for vacuum leaks, change fuel filter.
Old Oct 23, 2009 | 11:23 AM
blackcrossfire07's Avatar
I test drove a Base Crossfire 5 years ago when I was looking to buy one. I was in the car with the salesperson and it started running rough and shaking. Almost like it was trying to stall but it didn't. He called me the next day to sell me the car... said it was fixed and it was just a vacum hose that fell off. Maybe that is what you problem is.
I never bought that car... I ended up buying from a different dealer.
Old Oct 23, 2009 | 11:34 AM
LantanaTX's Avatar
Has the check engine light ever come on? I had a ML320 (same engine) do this with no check engine light at first and then it started dying when I came to a light. Eventually it would not re-start. It turned out to be the crank shaft position sensor. This sensor doesn't seem to just stop working all at once but rather go bad gradually. As mine started to go bad the check engine light finally started to come on but would clear itself after a few successful starts. Other possible causes are fuel filter. A vacum leak will also act just like this so pop your engine cover off and look all around. the oil filter is very easy to change. The big black plasic screw cap at the front of the engine is your filter housing. Just unscrew it and pop in a new filter while also replacing the various o rings. This is very easy to understand when you unscrew it.
I hope you get it to run better and you may even consider taking it to Autozone and have them scan it for free to check for any stored codes. Having the check engine light come on would be great as it would tell you the what is going on.
Old Oct 23, 2009 | 11:39 AM
Goldwing's Avatar
I use Speedway midrange and premium all the time and have no problems. You could have some bad gas or water in the tank from sitting. Add some gas line antifreeze and a bottle of gum-out. I have heard that a 1/2 quart of Seafoam in the gastank does wonders, but change the gas filter afterwards. Find a reputable garage who can change your oil and filter properly. Running the old filter (if it was new) with synthetic probably won't cause any problems because synthetic oil is 73% conventional oil anyway. But change both oil and filter next time. You may also want to change the air filters -- there are two, one on each side of the silver engine cover. The engine is the thingy in the front of the car.
Old Oct 23, 2009 | 11:43 AM
distantpulse's Avatar
Things I would check out in order....
Plug wires
Plugs
Clogged Injectors
Vacuum leak
Fuel Filter
Fuel Pump
If you are ruling out bad gas and it has trouble idling at a low RPM, it probably needs a tune up. Take it to a respected mechanic and have them look it over. I can tell you, I just changed my fuel filter (52k miles) and it was pure black coming out of it.
Old Oct 23, 2009 | 12:12 PM
Thanks all so much for the help. I'm going to take it to auozone to check it out bc I don't know how to look 4 stuff and have appointment at my dealer to look at it Monday. Hopefully it is fuel filter.
Old Oct 31, 2009 | 06:10 PM
jazzsvo1's Avatar
Yeah check all the vacuum lines , i was told that if the vacuum line that runs somewhere on the side of the motor,if has cracks it will defintely cause that motor to shake like that i took it in the conversation that i had with a mechanic that hose is commonly overlooked,happy boosting
Old Oct 31, 2009 | 06:16 PM
jazzsvo1's Avatar
Default Supercharger pulley bearing
Has anyone on this forum changed their bearing on the supercharger pulley itself i just recieved mine today i know the dealership charges $850 for the rebuild kit plus installation, can anyone assist me on how its done alsodoes anyone knowif the crossfire srt-6 rims and tires fit the c32 amg thanks
Old Nov 1, 2009 | 12:07 AM
Dougs's Avatar
I would check to make sure the engine cover is on properly. Could be that it's not sealed all the way down onto the throttle body.
Old Nov 1, 2009 | 09:02 AM
I had something very similar happened to me this spring after taking the car out of winter storage. I assumed it was because the gas in my car was from last fall. I through a bottle of Techron fuel system cleaner into the tank, and by the time I used up the gas it was fine. I do on occasion get the blinking low fuel light go on, but turning the car off, and restarting it takes care of that. It's only happen a couple of times.
This fall I'm adding some Sta-bil to my gas.
Then again, my Crossfire is black....
"Black Crossfires Rule"
Old Nov 1, 2009 | 10:46 AM
[quote=Goldwing]I use .......................................Running the old filter (if it was new) with synthetic probably won't cause any problems because synthetic oil is 73% conventional oil anyway. .......................quote]
You can buy oils that are a synthetic and conventional oil blend. But synthetic oil is, for a lack of a better word .... synthetic.
NORDVIK72
Aug 30, 2015 08:22 AM
firefly04
Aug 26, 2015 03:08 PM
NORDVIK72
Aug 25, 2015 11:43 PM
glover
U.K.
Aug 24, 2015 08:03 AM
glover
Aug 23, 2015 05:07 PM
