Things To Be Sorted
Old Oct 31, 2009 | 03:00 PM
FUBU's Avatar
Smile Things To Be Sorted
Things to be sorted:
- Turn off the alarm if seatbelt not on
Is this possible?
- Rear foglight
Should normally work (redlight) right?
- New buttons (volume / choice joggle ) for stock radio
Where to be found?
- Electric seat (passenger seat) only move back/forward and tilt.NOT up and down.
New motor needed?
- Seat heaters, disfunctional on driver seat, partially (butt) on passenger
Where can I find new kits to install myself? canadian 99 dollars?
- New set of car keys
100$ ?
- foggy headlights after carwash due to bad rubber seal?
How to do? any hints?
- left roof light does not work
probably lamp or circuit
- New set of car mats / rubber mats for winter use?
Where to find? Stock OEM ones?
- Best airfilter for XFIRE N/A?
ITG? K&N?
- Winter ski rack possible for crossfire?
Thanks for all the help.
Old Oct 31, 2009 | 03:24 PM
LantanaTX's Avatar
Default Re: Things To Be Sorted
Is this possible?
May be possible with DRBIII that Chrysler uses or maybe with the MB STAR system. How about unplugging the buzzer?
- Rear foglight
Should not work. Not used on USA cars. It may be possible to to jump wires from brake light to fog light so that you get more brake light. I did this to my Mini Cooper.
Where to be found?
Dealer maybe. I have seen them before on Ebay.
New motor needed?
That is all the passenger seat does.
Search forum
100$ ?
Must get from dealer and be programmed
Have been covered under warrenty. or Search forum or buy replacements. On Ebay all the time
Check light and if needed wiring
Join Crossfire club and they have some nice ones for sale or Dealer or Ebay
ITG? K&N?
K&N with stock engine cover.
I wish I was going skiing! Becareful of one tat attaches to the rear deck lid as it could interfer with with the wing.
Old Oct 31, 2009 | 04:48 PM
FUBU's Avatar
Talking Re: Things To Be Sorted
Hi! Thanks for all the answers.
[quote=LantanaTX]Things to be sorted:
Is this possible?
has the local chrysler dealer (Europe) access to those kind of systems?
Unplugging the beep thingie? well, not good if you drive off with the handbrake... But the seatbelt thing is quite irritating. I do use my seatbelt, but not when driving up the driveway.
Where to be found?
Okay, I found some radios, but I am only after the joggle buttons as they are dirty. Are they cleanable? :P I have not bought the car yet.
New motor needed?
Still, I checked a black (not base model) n/a one on friday. If I am not mistaken the passenger seat could also be lifted up. It should not only be the driver seat. Or? The black one was not US but a swedish one. But it should not differ.
Search forum
I have, no luck where to be bought. I need a kit for 2 seats.
100$ ?
Will do.
A warranty, still after 5 years? I would not think so...
Probably just to change the bulb / circuit
okay, you mean the cicci ?
ITG? K&N?
Still trying to find one.. prefferably in white..
Old Oct 31, 2009 | 09:36 PM
chevyboyac's Avatar
You can buy a key to put in your seatbelt buckle thingy and it will stop the beep. I found it on one of the websites that are advertised at the top of this site ^^^^^^
Old Oct 31, 2009 | 10:23 PM
bluedog's Avatar
Banned
......For twenty bucks?... not!. Just cut one from the back center seat of your wife's Jeep Grand Cherokee. She'll never know.
Old Oct 31, 2009 | 11:09 PM
blackcrossfire07's Avatar
For the seat belt beeper.... it eventually stops beeping.
Old Nov 1, 2009 | 12:27 PM
stryfox's Avatar
seat belt- just find the ground wire for the sensor and ground it. It will never beep again as the computer will see it as seat bet on.
There was a how to on it a couple years ago. I'll go look for it.
Old Nov 1, 2009 | 12:29 PM
stryfox's Avatar
https://www.crossfireforum.org/forum...elt-alarm.html
https://www.crossfireforum.org/forum...ning-chime.pdf
Old Nov 1, 2009 | 12:59 PM
FUBU's Avatar
Thanks stryfox! I will get to it when I get hold of the car! I am in the buying process! ;D opefully the owner will call me today and say that we shall do business. A white 2005 50000 miles N/A. nice condition also with a pair of winter tyres. GRRREaat!
Still trying to find some mopar parts though.. such as heat seater kits ...
Old Nov 1, 2009 | 02:56 PM
maxcichon's Avatar
If you end up with condensation inside the headlights after a wash or driving in the rain, there is a TSB that addresses this problem. You would have to pay for them to fix it but the kit costs $25 and can be installed in 5 minutes with one hand. Ask that they print out the install guide they would use for the tech to follow.
TSB: 13-Jan-05 - 08-002-05 - Lighting - Condensation in Headlamps
I did this install and it took care of the issue immediately. It is 4 large caps and 2 smaller caps installed on the back of the assemblies.
So easy a caveman...etc., etc...
Old Nov 1, 2009 | 04:12 PM
FUBU's Avatar
thanks dude!
I really like your engine bay. i will probably do the same but in white.. or some cool pattern. big up!
have a nice one
/ FUBU
Old Nov 1, 2009 | 04:46 PM
FUBU's Avatar
WHERE?!?!?! cannot find it...
Old Nov 1, 2009 | 04:54 PM
maxcichon's Avatar
There is a list of TSB's in the "TSBs and How-to articles" forum.
Open the "Forum Jump" drop-down menu at the bottom of any page.
Just copy this info down and carry it into the service department. This will tell them which TSB to look up and take it from there.
Thanks for the kudos! There is a thread called "Painted Engine Covers" or something like that. Some pretty neat ideas to be found...
Old Nov 1, 2009 | 05:29 PM
FUBU's Avatar
Sorry but I feel a bit lost.
What, shall I visit an external website? the all data? huh? visit the dealer? it is getting late here...
/ Phil aka mr not understand
Old Nov 1, 2009 | 05:42 PM
green-ghost's Avatar
man that's a really good how to
Old Nov 1, 2009 | 05:58 PM
FUBU's Avatar
Yep. Will be done asap as I get the car. He has not called yet. I gave him a counter offer. He said that he will be calling later this evening. He is in fl. I sm in Sweden. Evening got him is night for me fingers crossed.
Old Nov 3, 2009 | 01:43 AM
peter_k's Avatar
rmcdaniel12
Nov 4, 2015 04:08 PM
Oct 1, 2015 01:42 AM
Sep 28, 2015 07:40 PM
debradegiovanni
Sep 27, 2015 09:39 AM
cdcrone123
Sep 14, 2015 09:51 AM
