spoiler please help!!!
Old Nov 7, 2009 | 09:56 AM
Monopoly_Man's Avatar
Default spoiler please help!!!
So my spoiler has been out of commission for a few months now. This would not be then end of the world except it is in the up position and becoming quite the nuisance. I have checked all the connections and the fuse and they are fine. The battery has a full charge. Some please help I hope there is just something simple that i have overlooked.....
Old Nov 7, 2009 | 10:28 AM
Default Re: spoiler please help!!!!
I have some limited experience of messing with the spoiler. I am sure you tried to lower the wing with the manual switch on the dash? (simple but must ask). Does the switch blink or sound when you go 80 mph or faster? If it does, I would say to check out the "down limit" micro switch or circuit.
One step at a time. James
Old Nov 7, 2009 | 10:32 AM
There is no lights on the switch anymore, and yes i tried the switch (being that simple would be welcome now, im just so frustrated with it.)
Old Nov 7, 2009 | 10:44 AM
LantanaTX's Avatar
I would get to the motor with a volt meter and see if you are getting voltage to it with the key on and working the switch. this should tell you if you have a wiring problem or a bad motor.
Old Nov 7, 2009 | 05:33 PM
The Beep's Avatar
Might try pulling the + battery cable for a minute. See if it resets.
Old Nov 7, 2009 | 08:03 PM
Ok, if the 'down limit' switch would be stuck closed, telling the ECU that the wing is down, the ECU would never tell it to go down and you couldn't manuallly put it down. But since you are not getting the warning alarm above 80mph, then the ECU must know the wing is up.
More to think about and post again.
James
Old Nov 7, 2009 | 09:55 PM
Jeep2Xfire's Avatar
If there is no light in the up/down switch then check voltage on both sides of the switch. Wing could have been deployed when the switch blew.
Old Nov 7, 2009 | 10:21 PM
I have not had the dash apart to see if there is a seperate plug on the back of the manual wing switch. By disconnecting the switch, the wing should go down once the car is started if the switch is defective.
The manual switch works very interesting if you look at it close.
PS, also the diagram shows the "limit switches" as one unit. It is not, they are 2 seperate switches.
Old Nov 9, 2009 | 12:42 PM
So I have made some progress the wing now operates as i connected power from the battery after ensuring the motor was good. There is still no manual control at the switch which must mean there us a problem directly with the switch which i will replace and hopefully become problem free.
Old Nov 10, 2009 | 11:17 AM
patpur's Avatar
Senior Member/Moderator
Where in New Jersey? Glad you have the problem isolated, does sound like the switch.
Old Nov 10, 2009 | 08:27 PM
I am in Little Ferry NJ. Its just outside of NYC.
Lockhouse
Mar 20, 2024 04:50 PM
Reliableron
Oct 17, 2015 10:19 PM
atdavis2
Sep 21, 2015 01:25 PM
RacerXofFL
Sep 15, 2015 05:00 PM
davidc90
Sep 6, 2015 10:37 PM
