Handeling difficulty solution
Old Nov 11, 2009 | 01:44 AM
neroco2's Avatar
Default Handeling difficulty solution
Hi Everyone:
A couple of days ago I posted my problems about my 04 Crossfire handeling difficulties. I appreciate all your suggestions and here's what happened.
First, I made sure the tire pressure was correct, several ties were low. I also made sure all the lug nuts were torqued correctly. They were. No difference in the ride.
I took the car to Les Schwab in Newberg, Oregon (been doing business with them for over 30 years and they are excellent) John Vondrecek, the allignment/suspension/brake specialist discovered a bad right trailing arm. I also put on new front tires and had a four wheel thrust allignment.
Happy to say the car handles liike it is on a rail now. Perfect. What a difference. The cost for all this, a bit over $500. Not bad at all.
So, look at your trailing arms. I am also going to put on the steering damper myself.
Now, about that passenger low beam that illuminates two feet in front of the car. Any easy ways to snap it back where it belongs? Do you take the wire connector off first and then undo the spring clip second and then reseat the bulb? This is about as much fun as replacing the rear light bulbs in a C4 Corvette!
Neil
Old Nov 11, 2009 | 06:24 AM
waldig's Avatar
Talking Re: Handeling difficulty solution
I had a weird little rear kick every time I accelorated and was going all over the car looking for it. Found a trailing arm that was loose and it was causing the car to wanna step sideways a touch as I smoothly accelorated.
The rear needs to be checked for tightness in the 'suspension is weird' cases. Woody
Old Nov 11, 2009 | 06:27 AM
danimal's Avatar
Default Re: Handeling difficulty solution
Neil, you don't need to disconnect the wiring. Just undo the spring clip and rotate the bulb a little until in seats and clip it. Have fun.
Old Nov 11, 2009 | 10:07 AM
MikeR's Avatar
Neil, where are you at? I live up in North Plains just north of Hillsboro.
Old Nov 13, 2009 | 01:44 PM
ppro's Avatar
Default Head Light Adjustment
Originally Posted by neroco2
Now, about that passenger low beam that illuminates two feet in front of the car. Any easy ways to snap it back where it belongs? Do you take the wire connector off first and then undo the spring clip second and then reseat the bulb? This is about as much fun as replacing the rear light bulbs in a C4 Corvette!Neil
I just left the clip in place and moved the light assembly back against the clip and then adjusted it to fit properly on the seat. It's a pain to actually see what you're doing but there is a point where it feels "right" - once you have done it once or twice, you should be able to stick it every time. Hope you have small hands.
Old Nov 13, 2009 | 02:20 PM
neroco2's Avatar
The light bulb was in upside down so I had to disconnect everything and do it right. I removed the overflow tank and moved offending items out of the way. I used some hemostats and in 15 minutes had the task accomplished.
Neil Cohen
KDW4Him
18
Sep 1, 2021 05:47 PM
Nexxus
May 8, 2016 04:43 PM
nataliefs
Oct 5, 2015 01:03 PM
BEATv1
Sep 10, 2015 12:58 PM
Adrian_X
Jul 12, 2015 11:05 PM
